cam i found???
Old May 10, 2011 | 12:21 AM
Trezent's Avatar
Default cam i found???
found this cam really cheap. its a comp cams Camshaft.
i was wondering if it would be good with a blower setup. runnin a procharger on 10psi heads untouched but will be building them up soon.
here is the grind
LS1 3710R 3715R HR 114+2
Duration .050 Intake 214
Duration .050 Exhaust 224
Lift Intake 559
Lift Exhaust 567
would this work for my application. and what supporting things would i need. i am sure springs, pushrods and so on. also thinking of some 317 heads.
any input would be great.
Old May 10, 2011 | 03:27 AM
pewterliftedz's Avatar
what size motor?
Old May 10, 2011 | 05:57 AM
iamkeniff's Avatar
gotta be a 5.7-6.0 if he is thinking of running 317s bc a 4.8/5.3 normally wouldnt use those heads, unless he wants to try some something....
thats a pretty big split for a motor not using L92/LS3/LS7 heads. i think the thing you need to do IF you are wanting to go with a cam....do it once, not a million times. spend the little cash on a spec'd cam and be done with it. get with Pat G or Geoff on here and tell them what you have, what you want. they can hook you up
clean truck in your sig for sure.
Old May 10, 2011 | 08:31 AM
03sierraslt's Avatar
That cam would work fine, you want a 10-12 exhaust bias with a procharger and its 10. Could there be other better cams-yes but that would work just fine. What size motor?
I am running a 11 degree bias specd by patg that works nice with my TVS
Old May 11, 2011 | 04:47 PM
Trezent's Avatar
Thanx man
yeah thats cool its a 5.3L i was just wondering because i can ****** this cam for about 30 bucks if i want it. lots of people tell me the ls6 cam is pretty straight for blown truck.
i know absolutely nothing about cams and i am not even gonna attempt to fake it.
Old May 12, 2011 | 07:34 AM
iamkeniff's Avatar
try it! worst case you're out 10.00 for a crank bolt and 3-4hrs labor (if you know how to do it yourself)
Old May 12, 2011 | 07:43 AM
dmelvin's Avatar
How are you getting it so cheap? It's not a regrind is it?
Old May 12, 2011 | 11:46 AM
jrmchevyman's Avatar
I'd go for it for only $30 for that cam.. Cant go wrong. Also is it a regrind cam like dmelvin asked?
Old May 12, 2011 | 03:23 PM
Trezent's Avatar
yeah i can install myself my brother works at a machine shop and builds engines for a living.
and as far as i know its not a regrind.
Old May 12, 2011 | 04:14 PM
dmelvin's Avatar
I would find out for sure... most good used cams are around $150 at the cheapest... there's been more than one motor death due to reground cams.
Not trying to **** in your cherrios, I just really don't want to see you post a thread in 5 months with bunch of metal in your oil pan, chewed up lifters, or some other damage due to a cheap regrind cam.
