cam help
Old Jan 14, 2008 | 11:27 AM
cwalker2006's Avatar
Default cam help
have read on here for weeks, but still dont know what cam i want to put in my truck. looking for low end torque, but with nice upper end. not to many trucks around here. just a bunch of 4 and 6 bangers.ecsb 2wd. i have cai, pacesetter lt's, y-pipe, no cats. and a tune. right now im putting down 310rwhp and 335ft.lb. to the wheels. thanks for all the help.
Old Jan 14, 2008 | 01:23 PM
chris04's Avatar
you got a 5.3 or 6.0?
Old Jan 14, 2008 | 01:44 PM
i have a 5.3l
Old Jan 14, 2008 | 02:14 PM
chris04's Avatar
well thats weird why ur putting down 310rwhp and 335ft.lb. of torque i only put down 270rwhp and 289ft.lb of torque with my 5.3l with with cam and bolt on's, thats probably at the flywheel not rear wheels but anyway my buddy put a 212/218 in his 5.3 and that thing has wicked low end power and its good up top too, he ran a 13.9 in the 1/4 with that cam, long tubes, tune with stock converter and 3.42's. but his truck is also a scsb. but sounds like the cam you might be looking for
Old Jan 14, 2008 | 02:23 PM
xlcooplx's Avatar
I would suggest that 212/218 but he's also running Pacesetters...Unless he plans on running an aftermarket converter, he may want to drop duration a bit or either get some smaller headers...Those pacesetters in a heavy truck have to kill bottom end.
Old Jan 14, 2008 | 06:37 PM
my truck was dyno tuned at 310, ill post the dyno sheet sometime. yea my bottom end sucks. my rear end is only 3.23's. ill get a converter if necessary, you got an idle clip of the cam?
Old Jan 14, 2008 | 07:26 PM
xlcooplx's Avatar
http://youtube.com/watch?v=dmphuEGitVo
Old Jan 14, 2008 | 07:50 PM
thanks, what size stall should i get if needed?
Old Jan 14, 2008 | 08:02 PM
xlcooplx's Avatar
you dont need one but a 3000 would be great with it. you could run a lower stall as well...this cam doesnt deprive you of bottom end power.
Old Jan 14, 2008 | 08:10 PM
00Silv4.8's Avatar
so now Im wondering y xlcooplx ran a 13.9 with less mods than chris04 and a smaller cam as well? granted u dont have a time but 270hp wouldnt run faster than a 13.9 or close right?
