Cam/head guru's
Old Aug 25, 2016 | 09:18 AM
Thee caretaker's Avatar
Registered User
Default Cam/head guru's
I've only just started to wrap my head around cams but I've recently discovered I need heads I want to know what I need not some over top head I have a 5.3 with a btr stg 3 truck cam 218/224 .553/.553 113+3 look to do stall headers intake soon
Old Aug 25, 2016 | 09:32 AM
03sierraslt's Avatar
Depends how much you wanna spend and what the rest of the setup is. Are you looking for aftermarket or just want a good stock replacement that will optimize your setup?
Old Aug 25, 2016 | 12:06 PM
Registered User
I just want an upgrade doesn't really matter on price Want to make more power mostly
Old Aug 25, 2016 | 12:08 PM
FFDP's Avatar
What year is the vehicle?
243/799 heads are great upgrade over the 706/826 heads.
Old Aug 25, 2016 | 02:36 PM
Registered User
It's an 08 5.3 and it has both 243and 799 must have been a warranty they changed one out
Old Aug 25, 2016 | 02:58 PM
FFDP's Avatar
What's wrong with the current ones on your truck now?
Old Aug 25, 2016 | 06:26 PM
Ray Finkle's Avatar
If it already has 799/243 heads on it, I'd clean them up and run them.
Old Aug 25, 2016 | 06:40 PM
Registered User
They're both cracked between the valves
Old Aug 25, 2016 | 06:43 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Did you over heat it or something? That's usually the only time I see that.
Old Aug 25, 2016 | 06:51 PM
FFDP's Avatar
I'm different but I'd still run those heads if you have no other issues.
I come from the 3800 world before these trucks and I can bet you 80% of the engines out there have cracks between the valves and the owners don't even know it. New threads pop up every now and then when someone sends them off for cleaning or polish work and after a magnaflux the cracks show up. It doesn't change how the head performs so they bolt them down anyway.
