Cam and converter suggestion for 2012 5,3 crew cab
i got a 2012 crew cab 5.3 6speed with 3.42's. I been looking at a comp LSR 215/223 604 609 112lsa with a yank 2800 9.5 inch SST, Nelson custom tune, volant cai, corsa headers and a 22 inch magnaflow. What do you guys think. its my every day driver so its gotta do it all grocerys tow haul the hole 9 yards so to speak. Also might do a 3/5 drop....
Flow data on the 243/799 heads says the airflow drops off after .550 lift. So getting a cam with that much lift isn't going to do you a whole lot of good after .550. I'd go with a 3200 converter and Comp 212/218 to help with those 3.42 gears.. You'll also need to pick up a good transmission cooler. Depending on how much you tow, the 3200 converter may be too much in the Texas heat.
Looked at the head flow numbers. Seems the flow is equal from. 550-.600" lift so its not dropping off any just not going up. And yea gonna get the heads ported at some point.
