Cam Consideration
Old Mar 31, 2006 | 08:38 PM
ONLYA4.8L's Avatar
cool.. Thanks
Old Mar 31, 2006 | 08:48 PM
Flyer's Avatar
The 1st one u asked about is to much for a 4.8 with taht little compression. The 6.0 heads will drop the compression a good bit.
If you want big, maybe a TR224 on a 112 would be good. If you want it to idle better, put it on a 114. The 114 will prolly run a little better on that motor anyways.
Old Apr 1, 2006 | 03:27 PM
ONLYA4.8L's Avatar
So that TR224 on a 112 or a 114 will be good? I dont care how it idles... I just want the camshaft that will give it the most power Ima run stock heads for now when I get the cam in... Then Ima get the heads worked... Will I be good to mill the heads so the compression will stays the same? or should I just get em ported?
lawhitediamante
Aug 12, 2015 12:14 PM
OHsixLS3
Aug 10, 2015 07:19 PM
Austino
Jul 30, 2015 03:28 PM
steves86ta
Jul 28, 2015 10:21 AM
projectnightcrawler
Jul 19, 2015 11:30 PM
