cam came in
Old Mar 17, 2010 | 03:17 PM
fastjweb's Avatar
Default cam came in
im doing a custom grind cam from comp with longtubes and catless y, along with a vortech sq trim at 7lbs. msd wires, double roller timing chain, and dyno tune. cam specs are 224/236 610/610 108 lsa, i thought it sounded crazy big, but they insured me it work really well with what im doin. any opinions?
Old Mar 17, 2010 | 04:19 PM
03sierraslt's Avatar
This is in a 5.3? I hope not.. First off that cam is huge for a 5.3, second you are going to have a **** load of overlap with a 108lsa. Who said that cam would work well in your setup?
Old Mar 17, 2010 | 04:35 PM
LS1FREEK's Avatar
13 Second Truck Club
That cam is not HUGE for a 5.3, my cam is fairly close to those numbers and is VERY streetable. I have no stall and driving around on the street i dont even notice that i have it in there. But i do have to agree that the lsa is to tight and would give you to much overlap with those duration numbers. I would keep all the other numbers but go with a 114 to 118 lsa depending on how much boost your running.
Old Mar 17, 2010 | 04:39 PM
00ChevyScott's Avatar
Wearin' da big hat
LMAO a 108lsa with a S/C?
Old Mar 17, 2010 | 04:42 PM
budhayes3's Avatar
PT's Slowest Truck
Did I miss something, where does it say he's boosted? I sure hope not with that tight LSA
Old Mar 17, 2010 | 04:57 PM
LS1TRUCKGUY's Avatar
who suggested these specs? i hope not a reputable shop.... you should be in the 114-115 lsa range with a s/c
Old Mar 17, 2010 | 05:10 PM
fastjweb's Avatar
well, i guess we will see what happens, thanks for the input, ill be doin the mods in 2-3 weeks, so ill put up what itll do.
Old Mar 17, 2010 | 06:12 PM
TIM Z's Avatar
11 sec. Truck Mod
Good luck Bud !
Old Mar 17, 2010 | 06:18 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
This is going to be with a 2500 converter?
Old Mar 17, 2010 | 07:29 PM
budhayes3's Avatar
PT's Slowest Truck
Whoops, how the hell did I miss that??
