budget build. L92 iron or???
Old Feb 14, 2014 | 01:45 PM
Pro52R's Avatar
Default budget build. L92 iron or???
Ok. I acquired a LQ4. It's got high miles. It's an old Iron headed 6.0. I have arp rod bolts from my old LS1 and a crank. I also have a blown L33 short block.
I was thinking, the crank and rods from the L33 (since theyre floating) with the ARP bolts. Then either getting flat tops, or boring to 4.065 and run LS3/L92 slugs. It's going in my DD. I'd like maybe 450ish wheel. It's in a 2wd Yukon, with a lil weight reduction, so maybe 5200.
I'll build it one piece at a time. My other question, is cathedral or square ports? How would 243s with some work done be on a 6.2? I know alot of people say the Square ports, you lose bottom end. I'll of course stall it and a cam. I have 3.73s. Just looking for opinions from the gurus and getting knowledge on what will work. I'd really love to maybe hit them 12s.
Old Feb 14, 2014 | 02:48 PM
tim wellington's Avatar
Smile l92
450 rwhp is stout for n/a engine .what are doing for injectors ,throttle body and intake .
Old Feb 15, 2014 | 06:08 AM
dirt track racer 81's Avatar
It's either going to take a high compression pistons with l92 heads or some ported heads to make 450 with an auto tranny..
Old Feb 15, 2014 | 09:25 AM
Pro52R's Avatar
I figured the heads would need some work. I guess my main goal is to hit 12s. And should I go with the 4.000 or 4.065 bore.
I planned on needing injectors, and either a L92 intake, or NNBS with 90mm tb.
Old Feb 15, 2014 | 10:32 AM
batboy's Avatar
11 Second Club
While a lot of the 6.0 iron blocks can be bored to 4.065", not all can (especially the early blocks). If you seriously want to do this, have a machine shop sonic check the block. On the other hand, a 4.030" overbore is routine for these blocks and is what I would probably do.
Old Feb 15, 2014 | 12:20 PM
Pro52R's Avatar
It is an early block, so I guess I'll need to have it checked. I thought about a 370, but I'm trying to go budget. And I was going to get stock LS2 or LS3 pistons, due to being cheaper. Forget 4.030 slugs are considerably more.
Old Feb 15, 2014 | 05:20 PM
batboy's Avatar
11 Second Club
A high mileage block will need to be bored out, so regardless you are looking at new pistons.
KleanKustoms
Sep 30, 2015 05:07 PM
jscherbs
Sep 30, 2015 07:54 AM
xxloudogxx
Sep 28, 2015 12:30 PM
trevorh1
Sep 27, 2015 08:47 PM
sTNT971
Sep 26, 2015 04:22 PM
