Budget 5.3 Build up... Have a few quick ???'s
Old Jun 29, 2012 | 05:41 PM
chris99gmc's Avatar
Default Budget 5.3 Build up... Have a few quick ???'s
Alright. I blew the head gasket on the DD. didn't plan on doing anything to the 5.3 until i swapped in the 370/408 build... But plans changed cuz I need a DD that has 4 wheels. This motor has about 110k on it. Stock with cold air, new plugs, msd wires, 3" magnaflow exhaust, all new accessories, tranny cooler and radiator.. Nothing special.
I have a set of 853 heads milled .040 to 60cc with New Ls6 springs. Valve job with fresh seats/seals. Slightly ported polished bowls.... I'm using the graphite head gaskets cuz they have the notch. My block and the heads are both yr 2000.
-I have an Ls6 Cam from a 04 zo6.
-Comp 7.400 Hardened Push rods
-Complete Felpro Gasket set. (All gaskets from the heads up to the TB)
-Felpro Head bolts
-OEM Crank pulley bolt
Now, I've yet to hit the $200 mark on this build this far(actually the head bolts might have put me just over)... budget is key, although I'd opt to pay a little more now, if it saves me the headaches later, type of thing...
My questions before I start are:
-Am I missing anything or have a looked over something that should be replaced at this time??? ie timing chain or new oil pump? What about lifters and/or trays?
-Do I need new cam bolts and bearings?
-Do I need a different front engine cover/gasket for cam sensor for swapping in the Ls6 cam into the 5.3?
-And the stock balancer had a slight little wobble to it, so I want to replace it... My buddy has a fresh Ls1 balancer from a 2002 camaro. I realize the camaro pulley might be slightly shorter... but does it still work? or will I need to get a Balancer from a Truck/SUV only??
Old Jul 1, 2012 | 01:18 AM
1FastBrick's Avatar
Custm2500's Rude Friend
-Am I missing anything or have a looked over something that should be replaced at this time??? ie timing chain or new oil pump? What about lifters and/or trays? If there in good shape, then no
-Do I need new cam bolts and bearings? Not unless there damaged
-Do I need a different front engine cover/gasket for cam sensor for swapping in the Ls6 cam into the 5.3? NO
-And the stock balancer had a slight little wobble to it, so I want to replace it... My buddy has a fresh Ls1 balancer from a 2002 camaro. I realize the camaro pulley might be slightly shorter... but does it still work? or will I need to get a Balancer from a Truck/SUV only?? Need a truck unit
Answers in Red. Just take your time when doing the swap and don't for get to get a tune
Old Jul 1, 2012 | 05:29 PM
sand man's Avatar
id say change the oil pump while your in there,
Old Jul 2, 2012 | 02:50 AM
chris99gmc's Avatar
Do you think I'll have pushrod length issues with the heads milled .040, using 7.400 pushrods?
Old Jul 2, 2012 | 03:29 AM
blacknfast's Avatar
Registered User
No. If you are re-using old push rods just make sure they go back where they came from. Set your valve lash to spec
Old Jul 2, 2012 | 07:52 AM
JoeyGC5's Avatar
I think you might have a slight issue, But without final assembly and inspection its kinda a guessing game. If your to long I have a set of 7.350" hardened rods that I'd make you a great deal on.
Old Jul 2, 2012 | 09:29 AM
grey matter 04's Avatar
13 Second Truck Club
your pushrods should be fine milled .040 with the ls6 cam..thats my setup
Old Jul 5, 2012 | 04:50 AM
chris99gmc's Avatar
I've heard the ls6 cam requires a slightly longer pushrod. That's why I figured I'd be alright with the 7.4's on the milled heads.. I guess there is Only one way to know for sure..
Dan Neumann
11
Aug 7, 2022 09:06 AM
BoostedBowTie
Jan 3, 2020 06:46 PM
USMCvet0311
Aug 14, 2015 10:28 PM
steves86ta
Jul 28, 2015 10:21 AM
Matt331
Jul 26, 2015 09:40 PM
