BTR stg 4 Ls1/2 cammed 1500 HD Silverado
Old Apr 2, 2020 | 09:50 PM
Uppgrade's Avatar
Default BTR stg 4 Ls1/2 cammed 1500 HD Silverado
Rebuilt LQ9 with stg 4 BTR LS1/2 cam. Upgraded springs, dont remember the number. 11.1:1 compression. Stock unported LS3 heads, L92 intake manifold, stock airbox, stock 78mm TB, ARP everything, stock manifolds with gutted cats, and stock dual in/single out muffler. Stock 4L80e with Transmission Specialties single disk 3400 billet convertor. Stock 9.5" 14 bolt with 3.73's. No dyno number yet. I have the Speed engineering LT's and true duals from my other truck, just waiting to put it on. Also 456 gears are sitting at home and waiting to go in once things return to normal.
https://youtu.be/IkPghwg3X9M
Old Apr 3, 2020 | 08:17 AM
dantheman1540's Avatar
Sounds like rowdy ****. hows it drive?
Old Apr 3, 2020 | 08:19 PM
madmann26's Avatar
Awful choice in cam IMO.
To each his own though.
Old Apr 3, 2020 | 09:25 PM
Uppgrade's Avatar
I bought the engine as is from my buddy. I didnt 'pick' the combo. It was in his RCSB that he uses for roadcourse. But it runs and drives well. My LQ4 that was pulled had 300k on it, and held great oil pressure and was still quiet. And yes, to each their own.
Old Apr 3, 2020 | 09:27 PM
Uppgrade's Avatar
It idles rough, just like anything I've had before with a big cam. But with the convertor, it drives and takes off nice. Tighter feeling than I expected. Above 6k it feels like vtec, and shift points are 6700.
Old Apr 3, 2020 | 10:21 PM
68Formula's Avatar
"NA" or "Truck" Stage 4? Truck version wouldn't be too bad. The NA would be stupid-peaky for use in a street truck. Fine for a lighter vehicle on a roadcourse.
Are you using an adapter to run the 78mm TB on an L92 intake? If so, then it and the stock airbox are choking it. Which means you're not making effective use of the cam.
Old Apr 3, 2020 | 10:27 PM
Uppgrade's Avatar
Originally Posted by 68Formula
"NA" or "Truck" Stage 4? Truck version wouldn't be too bad. The NA would be stupid-peaky for use in a street truck. Great for a lighter vehicle on a roadcourse.
It's not the truck stage 4, it's the car stage 4. Yes, this cam is more ideal for something lighter, I 100% agree. A truck cam would be what I would recommend for a stranger if they wanted a cammed truck. But I got a good deal on this combo. I rarely tow with this truck. But I like the sound and powerband it offers.
Old Apr 3, 2020 | 10:37 PM
Slap a blower on it let it eat! If you like it then good. I wish my Tahoe had more cam mostly just for the sound.
Old Apr 3, 2020 | 11:03 PM
Uppgrade's Avatar
Sorry I didnt see all of your post. Yes, stock throttle body, 78mm, adapted on stock intake. the stock TB is good for 450 rwp from what I've heard. I did the bigger factory throttle bodies on my other 6.0 truck, with the x-link, and kept getting random misfire codes. It pulled stronger with the bigger TB, but the misfire codes drove me nuts. And yes stock airbox for now too. Once I finish the turbo build on my other truck, the CAI is going on this truck with the stage 4 cam.
Old Apr 3, 2020 | 11:07 PM
Uppgrade's Avatar
I plan on getting the combo on a local chassis dyno with stock airbox and exhaust, then install the cai and full exhaust with long tubes to see just how much it picks up.
