Broken valve spring
Broke a valve spring.
Spring was the original ones that come on the edelbrock heads. LQ9 motor with a 224/224 56x/56x 110lsa cam. Any suggestions on what springs I should replace them with? Its been a while since Ive kept up with whats hot.
How many miles on the heads and how high you reving it , and as far as what springs I'm no expert, but I think the PRC .650 have a perty dam good rep, heres the link for ya ........... http://www.texas-speed.com/shop/item...d=173&catid=48
The new generation of Comp Cams 26918-16 seem pretty rock solid, very quiet and good for .600" lift. I've put 60k on mine without a hiccup. I'm running AFR duals at the momment and they are definetely a lot louder.
Rick
Rick
I had one of the ls6 springs break bout 2 years ago. Been running patriots since then and last known mileage was around 50k. Last month and with the old cam they saw 6800 at the track.
For a quite combo I'd go with the PAC 1218's on this one!
http://www.texas-speed.com/shop/item...=1064&catid=48
