break in?
Old Nov 16, 2005 | 06:40 PM
METALMULISHA777's Avatar
Default break in?
im getting a TR220/220 112 .....is there any sort of break in time? should i use assembly grease or just oil .. also i use mobil1 in my truck ... do i need to use regular oil to break it in??? just lookin for some info thanks
Old Nov 16, 2005 | 08:00 PM
bluecajun5.3's Avatar
11 Second Truck Club
all you have to do is... make sure you clean off all the residue off the cam first. then coat it with some mobil one oil (in your case) and stick her right in being careful not to nick the cam bearings. mobil one should be fine to break it in, or just go ahead and put some regular oil b/c it will need to be changed after a 100 miles on the cam.
Old Nov 16, 2005 | 08:18 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
NO reall break in on the cam I would start it up let it idle for about 10 minutes so the idle relearns good may have to restart it a few times. Then take it out and run it through the gears say to 4K each gear a couple of times then hammer the **** out of it. Main thing is the new springs that you get. You will need 918s or the ever popular LS6 springs but break in procedure on that is 2-4 heat cycles before oyu beat on it. Also after you go have fun with the new cam for alittle bit come back and change the oil cause there is alot of chances for oil contamination.
Old Nov 17, 2005 | 02:03 AM
Old Nov 17, 2005 | 03:13 PM
el_cabby's Avatar
http://truck.ls1tech.com/forums/showthread.php?t=352720
Old Nov 17, 2005 | 05:50 PM
99Silver6.0's Avatar
Break in depends on the springs you are gonna use. If you use Comp 918's you DAM well better heat cycle them. Or youll be very sorry you didnt!!!!!!!!!!!!
Other than that. No break in on hyd-roller cams.
Lthompson
Sep 21, 2015 04:34 PM
FlowmasterMufflers
Sep 18, 2015 02:31 PM
TAPyvehc93
Sep 14, 2015 01:22 PM
lsxperformance
Sep 14, 2015 10:53 AM
pewter00
Sep 11, 2015 09:32 AM
