best heads $1200 or cheaper
Old Nov 25, 2009 | 01:20 PM
hirdlej's Avatar
Originally Posted by jophuss36
I'm not sure but I think the tfs as cast 220's are around that price
They're $1600 shipped. Not bad if you didn't have to buy a rocker shim kit or roller rockers. The shim kits are even a couple hundred dollars after shipping
Old Nov 25, 2009 | 02:06 PM
jophuss36's Avatar
wow I must have got a good deal because I paid 2050 shipped for my cnc'd 225's with valves just not assembled
But yes you would definatly need rockers so scratch that idea
Old Nov 25, 2009 | 05:55 PM
eallanboggs's Avatar
A cam swap is certain a lot cheaper than a set of CNCed heads, but if you have the money Darrell Russell's dad Burnell told me years ago before Darrell started driving TF for Joe Amato that "It's in the heads". I still believe that. Remember an engine is an air pump and a chain is only as strong as its' weakest link. That means if you put a set of heads that flow big numbers and your cam, intake and CAI can't keep up your engine is having an asthma attack. It's trying to suck in more air, but there is a restriction somewhere. Keep this in mind and do some baseline checks before you make major changes. You need to check VE, Calculated Load, MAF and STFTs at WOT just before the 1/2 shift. Your VE needs to be at least 80% for N/A and 100% for F/I. Once you make your changes do another log and compare the new values to your baseline numbers.
Old Nov 25, 2009 | 06:12 PM
terravast4's Avatar
Texas speed 5.3 2.5 great head for the price ported . Oversized valves and springs up to .650 lift.
Old Nov 26, 2009 | 02:08 PM
Truckshop's Avatar
i put these on my lq4. made a night and day difference and almost 40hp on the dyno. i paid $900 shipped for them used.
Old Nov 26, 2009 | 02:42 PM
jophuss36's Avatar
juSt curious what kinda hp did u make with thoes heads and a224 cam
Old Nov 26, 2009 | 04:55 PM
Truckshop's Avatar
here ya go
https://www.performancetrucks.net/fo...d.php?t=446380
Old Nov 26, 2009 | 05:27 PM
silveradokidd_4518's Avatar
243's P&P with higher lift springs...
Old Nov 27, 2009 | 08:02 PM
bulldogSS's Avatar
you should be able to find some used ported 853s or 241s for cheap. i picked up a set of stage II from Katech really cheap bare. ported by the right person they will flow as well as 243s ported.
Silveradorst07
Dec 31, 2015 12:04 AM
Mossyoakglock
Aug 28, 2015 12:49 PM
urdone
Aug 26, 2015 01:24 PM
fiatdale
Not Manufacturer Specific Parts
Aug 26, 2015 07:36 AM
87caprice318
Aug 21, 2015 03:03 PM
