Assembling my 408, bearing tolerance?
Old May 5, 2007 | 11:27 PM
Stoichiometric's Avatar
Default Assembling my 408, bearing tolerance?
I am working on my 408 this weekend and came up with a few questions. First, what clearance is acceptable for main bearings and journal bearings? I have .0015 on the mains now, I think is OK but I am not sure. I have not tried the rods yet, but I should get them on tomorrow.
Second, does anyone have the part number for the ICS Titan head gasket off-hand? I found multiple part numbers and wanted to double check to make sure I order the right set.
The Caddilac lifters should be here soon and the WCCH Edelbrock 245s and VicJr will be going on soon .
Thanks!
Old May 6, 2007 | 07:37 AM
TurboGibbs's Avatar
That is a little on the tight side for me. It is within a runable spec but for a performance engine i'd stray to .0025-.0035 on the mains and .002-.003 on the rods. Putting them on the higher end generally requires a little heavier oil like a 40w but gives exra protection when deflection occurs at high engine loads IMO.
Old May 6, 2007 | 09:49 AM
moregrip's Avatar
what a rush!
everyone I talk to likes more clearance than that for a performance oriented engine
Old May 6, 2007 | 11:10 AM
Thank you for the help. I am going to check the rods out today, I may need to order .001 over bearings. I don't want to have any worries in the back of my mind once this is assembled and running.
Old May 6, 2007 | 11:22 AM
TurboGibbs's Avatar
The last couple I've built I had to go with .001 over mains.
Old May 6, 2007 | 06:39 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
I have a set of .054 titans brand new if you are interested that I ended up not using in my rebuild.
Old May 7, 2007 | 08:04 AM
mwalls54's Avatar
Need More N2O Mod
I will 2nd that, my 1st 408 had loose tolerances (performance) but were still in spec and i had 15-20lbs of oil pressure at idle with 20w50 royal purple racing oil.
Old May 7, 2007 | 10:07 AM
zippy's Avatar
Thanks!
That's within factory spec, I'd stick with that.
lukn4trbl355
Oct 21, 2015 11:19 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
blown02408
Oct 1, 2015 01:06 AM
trxmxzx
Sep 29, 2015 07:42 AM
sTNT971
Sep 26, 2015 04:22 PM
