assembling a 408 for future turbo , need alot of advice/info
Old Nov 27, 2012 | 09:19 PM
  #21
Atomic's Avatar
I have a gauge for that
Thats harder because you need to know what pistons and rod lengths are available combined with the heads you want to run to get the compression you want.
Old Nov 27, 2012 | 09:36 PM
  #22
sand man's Avatar
6.125 rods
heads are stock L92
deck hight is 9.235 with Iron blocks as I read here and there .
would a .005 mill be enough to level the surface . Im getting the blcok to the machine shop today
Old Nov 29, 2012 | 08:54 PM
  #23
sand man's Avatar
-assembled the pistons and rods .
- droped the block at the machine shop to be bored & honed,decked , and line honed.
-will get the heads saturday , hand ported and polishd , will do a 3 angle valve job done to them. and valve lap them if needed
-cam is here, arp bolts and studs ar here
-waiting on the block to check for clearnces on mains,rods and moving parts
Old Dec 3, 2012 | 09:52 AM
  #24
sand man's Avatar
decked , line honed , and bored,
the block was a little wavy , removed about 0.004" from it , and its smooth and looking good!
after some mesurements with ARP studs in place and nuts torqued , the clearnces are
from 1 to 5 :
1st 0.0017" - 2nd 0.0017" - 3rd 0.002" - 4th 0.0018" - 5th 0.0019"
asfter some honing and hand polishing :
.002 - .0021 - .0027 - .0022 - .0021
the pistons measured 4.027 and I added the clearnce suggested by wiseco , 0.0035
4.027+0.0035=4.0305"
mocked up the #1 #2 and #7 #8 pistons , the thing is , rod to rod clearnce on the 1 to 2 is 0.025" and the clearnce between the 8-7 is 0.006" ,,, is that a problem or should I proceed with the assembly ?
Old Dec 6, 2012 | 02:30 PM
  #25
sand man's Avatar
short block done !!!
Old Dec 7, 2012 | 04:19 PM
  #26
sand man's Avatar
Long block done ! droping the engine tomorow and cranking it by night time wish me luck!!
Old Dec 9, 2012 | 04:02 AM
  #27
sand man's Avatar
IT'S ALAIVE!!!
what break in method do you guys use?
Old Dec 9, 2012 | 04:46 AM
  #28
sand man's Avatar
the most resonable thing I have read arround LS1tech is this (almost the same of what GMPP recomended for their crates)
warm up check for noises under Idle RPMs , cool down , change oil , warm up drive it and do 5 to 6 passes @ 40-60% thottle to 4000 RPM and let of each time to idle rpm ,
run it agine 2 to 3 passes @ WOT 100% to 4000 RPM and let of each time to idle rpm
replace oil for the last time , take it to a dyno and hamer it !!
Old Dec 9, 2012 | 03:08 PM
  #29
oakley6575's Avatar
Put it in a low gear so when you get it in the upper rpm range, you can let the engine rpms come down on its own. That will help the rings seat. Hope that makes sense.
So put it in first gear, drive it to 4000+ and then just let the engine brake until its under 1500 rpm or so. Do that a few times
Are you running any break in additive?
Old Dec 9, 2012 | 04:02 PM
  #30
sand man's Avatar
no , just the assembly lube , 75% of what I read say I dont need any .
