ARP Heads Studs
Old Jan 5, 2008 | 02:06 PM
ZZebes's Avatar
hmmm makes you think
Old Jan 5, 2008 | 02:11 PM
Wilde Racing's Avatar
How do I change this text
I really need to hear (see) some reasons behind studding the heads. I know it was necessary in the past, but is it REALLY BETTER?
Torque-To-Yield
Torque-To-Yield (TTY) is a term that you should be familiar with because it describes a type of head bolt that is used on many late model engines. Unlike ordinary head bolts, TTY head bolts are designed to deform - but do it in a controlled way. Like a standard head bolt, a TTY bolt will stretch and spring back up to its yield point. But once the yield point is passed, the bolt becomes permanently stretched and does not return to its original length. Because of this, TTY bolts should not be reused.
Why intentionally stretch the head bolts? Engineers discovered they can get much more even clamping on the head gasket if all the bolts are evenly loaded. Since variations in friction between bolts always causes some uneven loading, stretching the bolts guarantees all the bolts will exert the same clamping force regardless of the torque reading on the wrench. The result is improved cylinder sealing, longer head gasket durability and less cylinder bore distortion (for reduced blowby and more power).
Old Jan 5, 2008 | 02:24 PM
Maybe I should start a new thread on this.....?
From ARP's web site...
2. Do I need head bolts or studs for my engine?
This depends on the installation. On many street-driven vehicles, where the master cylinders and other items protrude into the engine compartment, it’s probably necessary to use head bolts so that the cylinder heads can be removed with the engine in the car. For most applications, however, studs are recommended. Using studs will make it much easier to assemble an engine with the cylinder head and gasket assured of proper alignment. Studs also provide more accurate and consistent torque loading.
Old Jan 13, 2008 | 11:01 AM
TURBHOE's Avatar
i'd like to know more too. like will tty bolts work for my 10.4:1 scr 383 with 5psi of turbo boost?
Old Jan 13, 2008 | 11:52 AM
I posted up in ls1tech here...
https://ls1tech.com/forums/showthread.php?t=841056
And here
https://ls1tech.com/forums/showthread.php?t=841516
I also did a bit more research, and I will be using TTY bolts for my 370 build which I hope will make around 900hp at the crank......
03chevytruck
Nov 7, 2016 04:43 PM
JordanH
Aug 8, 2015 07:59 PM
4B11T
Jul 13, 2015 03:48 PM
ChevyLee
Jul 10, 2015 10:56 PM
NuckenFuts
Jul 9, 2015 08:45 AM
