another one of these threads
Old Feb 5, 2013 | 02:20 PM
Area47's Avatar
Default another one of these threads
in a sense, but still the same. i got hit with the fun question of "i want to do a heads/cam setup on my 04 avalanche" the fun twist of this joy is, wants to keep the stock stall. this limits my fun and throws my happy lets make 400whp out the window.
the cams im looking at from comp are, 212/218 522/529 on a 114, and a 216/220 525/532 on a 114. nothing to extreme in terms of duration and lift. might be on the edge of the stock converter and may have just a touch of minor surge off idle. mild cam choice, not a problem. the problem im running into is the flooded market of heads to match the cam. his main concern is torque, hence the smaller cam choices. i can see it gaining from a raised comp ratio due to a smaller cc chamber.
or say screw it and put a blower on it and call it a day.
Old Feb 5, 2013 | 02:36 PM
2000chevysilverado's Avatar
FI work better imo since doesn't want to change stall but wantn to achieve a power set point
Old Feb 5, 2013 | 03:04 PM
Area47's Avatar
im not sure what the budget is on this whole thing either. i know there isn't **** done it it. maybe an intake and thats pushing it. id be doing the tune on it, and probably some of the install as well.
Old Feb 5, 2013 | 03:45 PM
Mangled03gmc's Avatar
Baltimore Whore
This as far as needs of a stall and all. I can put it this way. I drove my truck with the stock converter on a basically stock tune( hypertech) for a long time with a 224 cam on a 112 lsa. It wasn't ungodly to drive by any means at least in my book. Yes occasions I had to 2 foot it but also was possibly due to not being tuned. With that being said yes a converter will almost all ways make a cam shine. But in alot of cases with the correct tuning you can get away with a decent cam on a stock converter. Naturally slapping FI is the easiest way to go, but budget isn't always there to do that all at one time..
Old Feb 5, 2013 | 03:52 PM
TIM Z's Avatar
11 sec. Truck Mod
Do the xr265hr Z06 springs and tune , it will run damn good and be a great DD .
Had this stick in my 04 5.3 Ecsb , both N/a and turbocharged , what a great cam .
Then go from there if its not enough power / fun for ya or whoever
This was back in about 05' or so , and what got me wanting that cam was riding in an 02 2500 HD , with an LQ4 and same cam, that truck ran soooo good .
Old Feb 5, 2013 | 03:56 PM
Area47's Avatar
that was actually the cam i sent him to take a look at
Old Feb 5, 2013 | 04:01 PM
TIM Z's Avatar
11 sec. Truck Mod
Well great minds think alike haha !
Old Feb 6, 2013 | 02:19 PM
Vortec350ss's Avatar
I've heard in a 6.0 that cam has a very similar power curve to the stock engine but makes more of it everywhere... must be pretty fun to drive
Tydriver
45
Oct 23, 2015 09:19 PM
trevorh1
Sep 27, 2015 08:47 PM
