Another help a guy build an LS thread
Old Apr 20, 2025 | 12:42 AM
  #21
1FastBrick's Avatar
Custm2500's Rude Friend
Attached is the DTC chart for P0341.Sounds like an Electromagnetic interference issue...
You should look at the Freeze frame failure and see when this code occurs.
Considering you had a P0342 and a P0343 which is Signal Low and Signal High codes you could have a pin fitment issue at the connector or a wiring issue.
File Type: pdf
Old Apr 23, 2025 | 09:22 AM
  #22
Summitracing's Avatar
LS1Tech Sponsor
@slowburb,
Nice work getting everything up and running! Sounds like @1FastBrick has you headed in the right direction with the DTCs. There is always a hiccup or two when taking on a project like this, so it's nothing out of the ordinary.
Wykkyd
11
Mar 12, 2024 02:30 PM
70CST
37
Oct 22, 2020 02:15 PM
adam7
32
Apr 18, 2018 06:40 PM
NorCalAnthony
Oct 21, 2016 11:01 AM
AUTOT3K
30
Nov 24, 2012 10:23 PM
