Another (Which cam should i get)?
Old Oct 30, 2007 | 05:27 PM
2001AntiVenom's Avatar
Default Another (Which cam should i get)?
My friend has a 2005 5.3 ex cab. I sold him my ls1 heads, ls6 intake, and ls1 injectors. he wants a cam too but the one i have is way to big so i gave him my stock ls1 cam. What is the best cam to put in his motor with them items? A big one that is choppy and give it plenty of power?
Old Oct 30, 2007 | 05:49 PM
sbw9056's Avatar
In stock configuration the 5.3 heads have 61.5cc chambers and the LS1 heads have 66.67cc chambers. I would be concerned about his compression ratio dropping by putting LS1 heads on a 5.3.
Old Nov 2, 2007 | 04:40 PM
yeah he is going to get them milled down. Thats another ? How far should they get milled to be fine?
Old Nov 2, 2007 | 09:53 PM
Richard@WCCH's Avatar
FormerVendor
Mill the LS1 heads at least .030". His truck should run quite a bit better with the heads, cam and intake upgrade.
Richard
Old Nov 3, 2007 | 05:54 PM
Richard
Thanks man. What is a good cam to put in it with that setup? Whats the biggest cam, that is street able without having a stall. that produces a lot of power still?
Old Nov 13, 2007 | 11:49 PM
Jessica's Avatar
Restricted User
WTF do you want the BIGGEST CAM you can get in a truck for?
Honestly anything over about a 224 on the intake is too much if you have over 4500lbs or smaller than about a 3200rpm stall.
2500ZL1
Jan 25, 2016 06:30 AM
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
