advance or retard on cam
Old Aug 10, 2007 | 02:39 PM
xdanny510x's Avatar
Default advance or retard on cam
like the title says my mechanic is doing the finally touches on the installation of the cam and he asked me @ what advance shuold i have it on.. its in a 2005 silverado 5.3
and the cam spex are 224/224 114* .578" lift
so were do u think it would be best??/
Old Aug 10, 2007 | 11:01 PM
N4cer's Avatar
10 Second Club
That depends on your heads, intake, exhaust system, and your goals.
Old Aug 10, 2007 | 11:03 PM
Stoichiometric's Avatar
If the cam is ground with 0 advance, +2 or +4 wouldn't hurt if you have an adjustable timing set. More advance=more low end power.
Old Aug 10, 2007 | 11:18 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
+1 at the cost of a little of the top end.
Here are my dyno graphs at 0*
and with 4* advance
damn that's hard to see, sorry but you can see the loss of 9hp and the gain of ~ 5lbs torque but the peak hp is quite lower in the powerband.
Old Aug 10, 2007 | 11:25 PM
Did you swap cams or have an adjustable set? Which did you like the feel of more?
Old Aug 10, 2007 | 11:40 PM
trever1t's Avatar
Only change was advancing it 4*. This was before I went FI. I liked it better with the 4* .
Those graphs are for the cam Danny is installing.
Old Aug 13, 2007 | 11:22 AM
TXARKITEKT's Avatar
Since you have a relatively high lift cam, go ahead and do 4* advanced. It will help out with the low end that you are loosing from going with the high lift...
Old Aug 13, 2007 | 11:40 AM
N4cer's Avatar
10 Second Club
High lift is supposed to assist low end, not hurt it.
Old Aug 13, 2007 | 01:06 PM
whitesilvy04's Avatar
Sweet, thanks for posting up that dyno sheet Trever1t
Old Aug 24, 2007 | 07:48 PM
SSmikeSS's Avatar
Wouldn't 4* advanced help in the 1/4 mile?
OHsixLS3
Aug 10, 2015 07:19 PM
noproblems209
Aug 10, 2015 06:57 PM
Hmguyton
Aug 9, 2015 05:38 PM
Mr. Chainsaw
Aug 5, 2015 07:54 AM
