650hp Street Friendly Motor?
Old Jul 6, 2012 | 12:19 AM
sowaidi's Avatar
Default 650hp Street Friendly Motor?
I would like your guys' suggestions for a motor build. I am in the process of buying a built motor for my RCSB 04 truck and I would like to get over 510rwhp and still be street friendly. Would a LS7 427 with high flow heads (PRC247cc or ported LS7 heads) and a medium cam be enough or would I have to step bigger for the LSX454? And If I do step to the iron LSX454 then I'd probably want more power like 530rwhp.
I am keeping my truck as a sleeper and driving it almost daily but I do not want to have issues with the 4.125 stroke so I was more interested in a 427. Its really hot where I live now and I use the AC whenever I'm driving.
The truck has a T56 and 4.10s so I would think that would help with drivetrain loss
All input is appreciated.
Thank You
Old Jul 6, 2012 | 12:24 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
I have an lsx 427 in my c5. I used 245cc Edelbrock heads and 237/246 cam. I think it will get it done. I haven't dyno'd it, but it sure feels like 550ish to me.
Keep in mind that 'street friendly' is a relative term
I think the easiest way to hit your goals and maintain good street manners is a 10:1 370 with a turbo.
Old Jul 6, 2012 | 01:55 AM
sowaidi's Avatar
Thanks a lot for your reply butI would want it to be NA. How's your cam treating you, is it too rough wheb it idles? My builder suggested a 235/239 so it would help in low rpms. I might step up just a bit bigger in the cam but I am not very knoledgeable so all comments and replies are very appreciated
Old Jul 6, 2012 | 07:20 AM
06murder's Avatar
built motor and street matters....cant have your cake and eat it.... but a with a 427 who cares bout ac roll windows down
Old Jul 6, 2012 | 08:03 AM
LS1TRUCKGUY's Avatar
Any particular reasons why you are against forced induction? A mostly stock 5.3 with a turbo or blower will make well over 500 to the wheels. Idle smooth, reliable, and much much much cheaper than a ls7
Old Jul 6, 2012 | 08:27 AM
JoeyGC5's Avatar
I've been beating the **** outta the 416 in my Vette for years. LME shortblock with LME prepped L92 heads and matched L76 intake. I use a 244/252 cam which at the time was thought to be perfect. But depending on the heads the cam choice would be the critical part of your larger motor build.
Old Jul 6, 2012 | 09:11 AM
nonnieselman's Avatar
I see this in his SIG..
"2004 RCSB - LQ4/T56 - 212/214 .558”/.559” 116LSA GT67@10psi - Auburn & 4.10's"
Just need more boost and your well past 520hp..
Old Jul 6, 2012 | 09:18 AM
Bodis22's Avatar
I thought I wanted a very strong NA engine as well and looked into doing so. After comparing the cost of a built LSX427 vs a fully forged stroker (383) with all good parts and turbo build I stayed FI. I can get close to double the horsepower at 50-75% the cost.
Old Jul 6, 2012 | 09:32 AM
It is pretty hard to beat the sound of a turbo
Old Jul 6, 2012 | 10:14 AM
black00chev's Avatar
Slowest turbo build ever!
I would swap out that 67mm for a 76mm on that LQ4 and call it a day. 500hp @ 10psi would be no problem and should drive exactly like stock untill you mash the go fast pedal .
