6.2l swap
Old Mar 7, 2007 | 02:09 PM
ojoojo's Avatar
Default 6.2l swap
Hi,
I Have A New Gmc Seirra 5.3 L Engine 2007 Model (new Shape) I Want To Swap To New L92 Engine 6.2 L (2007) In The Same Vehicle. Will It Work Or What Is Required To Be Done ? Please Advice
Old Mar 26, 2007 | 11:48 AM
8ty8 LS1's Avatar
motor mounts and whatnot should be the same...
Old Mar 26, 2007 | 03:30 PM
TURBHOE's Avatar
computer tune and peice of the wire harness should be diffrent for sure due to the variable cam timming and dod if applicable. manifolds (intake and exhaust) are pobably diffrent. for sure intake is not the same. othere than that it should all be close. oh and knock sensors are in diffrent spot the 5.3's are in he galley unless they change all the motors to the one on the out side. its doable for sure but its not a straight bolt in. now a 02 with a l92 top end is a diffrent story .
Old Mar 26, 2007 | 10:43 PM
ZZebes's Avatar
If he has a GMT-900 than it should be an almost direct swap like a 5.3 to a 6.0L
Old Mar 27, 2007 | 05:26 AM
TURBHOE's Avatar
6.2 is a diffrent beast no 5.3 has variable cam timming and the 6.2 does. alot of them do have the dod though so might be good there. the ecu has to have a diffrent total tune for sure.
Old Mar 27, 2007 | 10:23 AM
ZZebes's Avatar
thats true i forgot about the cam phaser
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
rednekferlife101
32
Jan 8, 2016 10:42 PM
05GMC4.8
Aug 7, 2015 09:55 PM
Nimoryan
Jul 5, 2015 03:50 PM
6.2AllTerrain
Jul 5, 2015 07:29 AM
