6.0 Rebuild
Old Mar 29, 2010 | 05:59 PM
  #21
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by Atomic
Its my opinion that a lot of mistakes that are made with changing oil pumps and timing chains are made because it is rather uncomfortable and akward to do that on an engine thats already installed. If its done before its installed I feel much better about it since it is much easier to work on.
I agree, with the engine on a stand, replacing the oil pump, timing chain, etc. is a piece of cake.
BTW, I'd be a little scared to run 11:1 static compression in a boosted application, 10.5:1 is as high as I would go, and that's with a rich, conservative tune
Old Mar 29, 2010 | 06:15 PM
  #22
Atomic's Avatar
I have a gauge for that
Yea im thinking 10.5 is more reasonable. Definitely a boost over the 9.5 of the LM7.
An LQ4 with flat top pistons and 317s would be around a 10:1 if im not mistaken, how much should be milled to bring that to 10.5:1? Im thinking a 4.03" bore is pretty sexy as well and gives me the option of bigger valves.
now a 408 stroker is looking appealing. I need to stop before this gets too expensive
Old Mar 29, 2010 | 10:15 PM
  #23
Bo185's Avatar
An LQ4 with flattop would be basically be a LQ9 and have 10:1 CR.
I would keep the dished pistons. Re-ring, new main/rod, bearings, oil pump, timing chain and arp rod bolts. Add boost and enjoy!
Old Mar 29, 2010 | 10:21 PM
  #24
EVILGMC's Avatar
10 to 10.5 compression. overdrive the 1900 with an 8-rib and have fun.
Old Mar 29, 2010 | 10:31 PM
  #25
budhayes3's Avatar
PT's Slowest Truck
Richard at WCCH told me to take .036 off of my StageII 317's to get 10.6:1 on my LQ9, but the StageII's have about a 74cc combustion chamber after the cnc bowl work that they get...so with unworked 317's you'll take less than .030 off...maybe .020 if I were to "guess"...
03sierraslt
14
Oct 9, 2015 05:53 AM
turbo6c3
Oct 5, 2015 06:11 PM
gmcyukon
Oct 5, 2015 06:20 AM
trevorh1
Sep 27, 2015 08:47 PM
sTNT971
Sep 26, 2015 06:27 AM
