which 6.0
Old Sep 5, 2007 | 11:53 AM
2005greenchevy's Avatar
Question which 6.0
is the 6.0 out of a 2500hd 2002 a straight swap or does it have the longer crank bolt?
Old Sep 5, 2007 | 08:17 PM
454SuperSport's Avatar
2002 has the short crank, remove the spacer and 6.0 flexplate and use the 5.3 flexplate if your using the 4l60e.
Old Sep 19, 2007 | 02:41 PM
custom 68's Avatar
when were there differences? sound like an easy fix but what years are a direct bolt to a 4l60e?
Thanks
Dave
Old Sep 19, 2007 | 06:46 PM
adam1803's Avatar
Thanks
Dave
None are direct bolt ons, if you want to use a 60e you need to swap out the flexplate.
Old Sep 19, 2007 | 08:09 PM
99-00 6.0's have the longer crank, they also have iron heads. 01'+ have the standard crank that used a spacer between the crank flange/flexplate to compensate.
Old Sep 19, 2007 | 08:20 PM
custom 68's Avatar
thanks guys I was not sure... sounds like a simple fix though
Old Sep 20, 2007 | 03:30 AM
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
It's really simple I did mine last year and it's still kicking
GMCtrk
18
Oct 6, 2015 03:48 PM
turbo6c3
Oct 5, 2015 06:11 PM
Cammed4ever
Sep 30, 2015 03:38 PM
trevorh1
Sep 27, 2015 08:47 PM
sTNT971
Sep 26, 2015 04:22 PM
