5.3L which cam
Old Feb 3, 2007 | 11:06 AM
onebadrubi's Avatar
yes all ls1 cams will fit. and yes those cams will be streetable.
Since you are using a 6 speed you can get away with a little more cam then the auto's and still be DDable and your car probably wieghs less then these trukcs.
When running that big of a shot of nitrous tho I would get atleast a 4-6* difference between int and ext duration.
Old Feb 3, 2007 | 08:19 PM
man this is alsome thank you guys for helping me picking out which cam...i will choose 222/228 with 114lsa but what kinna spring can i use and push rod
Old Feb 3, 2007 | 08:47 PM
would this cam is the same one u talking about onebadrubi would this cam for good nitrous and streeable?
Brand: Lunati
Product Line: Lunati Voodoo Camshafts
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 2,000-6,600 RPM
Intake Duration at 050 inch Lift: 222
Exhaust Duration at 050 inch Lift: 228
Duration at 050 inch Lift: 222 int./228 exh.
Advertised Intake Duration: 272
Advertised Exhaust Duration: 278
Advertised Duration: 272 int./278 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.567 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.567 in.
Valve Lift with Factory Rocker Arm Ratio: 0.567 int./0.567 exh. lift
Lobe Separation (degrees): 113
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Computer Controlled Compatible: Yes
Old Feb 3, 2007 | 08:59 PM
dirtyratt's Avatar
Im using the comp cams 7.4 High tech push rods there just a little longer then stock.When I had my Gt2-3 cam the upper valvetrain had a little noise with the new push rods and the bigger cam it is very quite now
Old Feb 4, 2007 | 12:58 PM
onebadrubi's Avatar
that cam would like the juice.
Might want to look at a Comp cam with XER lobes. That will give you a little more lift at the same duration.
Your most likely going to need comp 918 springs and pushrods just ask whoever you get the cam from.
Try calling Texas speed(sponsor to the right) they are pretty helpful and can grind the cam you want.
Old Feb 4, 2007 | 09:52 PM
this alsome i will call TSP and see thanks guys
Old Feb 4, 2007 | 10:15 PM
hi guys i just found this cam for a good deal Comp Cams 224/228 .567/.588 114lsa you guy think this will be good for it or this will get my gas miles down?
Old Feb 4, 2007 | 11:20 PM
onebadrubi's Avatar
Thats not a bad cam. If its used make sure its not pitted or nothin.
Old Feb 5, 2007 | 12:26 PM
ok thanks guy for helping got my cam on the way
lawhitediamante
Aug 12, 2015 12:14 PM
LARRY01Z28
Aug 1, 2015 10:15 PM
lxcoupe
Jul 27, 2015 08:19 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
