5.3 Won't turn when main caps are torqued
Old Mar 28, 2013 | 04:57 PM
gmcyukon's Avatar
Default 5.3 Won't turn when main caps are torqued
Sup guys got 02 5.3 and I torqued the main and rods and motor won't turn. I got the heads on and the plugs are out. Cam is in along with the rockers, pushrods, and those are torqued also. I just untighten the mains and the Motor turn fine. I torqued the main to 15 ft lbs and 80 degrees
Old Mar 28, 2013 | 05:09 PM
06murder's Avatar
Your sure your main bearings are right? Did you use stock or aftermarket bearings?
Old Mar 28, 2013 | 05:14 PM
gmcyukon's Avatar
These are stock std bearing
Old Mar 28, 2013 | 05:21 PM
06murder's Avatar
Did you use a degree gauge?
Old Mar 28, 2013 | 05:27 PM
gmcyukon's Avatar
No I didn't this is my first rebuild
Old Mar 28, 2013 | 05:29 PM
dirt track racer 81's Avatar
Post a pic of all 5 main caps.. My guess is you have one turned around. And in that case it won't spin, even if the caps are from another motor the crank won't spin..
Old Mar 28, 2013 | 05:30 PM
quicksilverado's Avatar
Wrong or swapped main caps, incorrect bearings or bent crank.
Old Mar 28, 2013 | 05:34 PM
06murder's Avatar
Degree wheel are cheap at part store. Likes dirt track said, you may have one on backwards.
Old Mar 28, 2013 | 05:39 PM
gmcyukon's Avatar
Old Mar 28, 2013 | 05:41 PM
gmcyukon's Avatar
I had to sets of mains . I had a set of 00 and 01 mains . I'm rebuilding the 00 with 01 mains I'm going to switch the mains
