5.3 towing Cam owners come on in
Old Feb 13, 2012 | 04:02 PM
grey matter 04's Avatar
13 Second Truck Club
heres a 212/218 dyno so you can compare the 2 cams
https://www.performancetrucks.net/fo...-474976/page3/
Old Feb 26, 2013 | 09:18 PM
shaw_426hemi's Avatar
Looking into options for my old mans rig. 05 5.3 60e, looking to tow 5000lbs cross country. Whats the best options for him to get some tow power? My research is suggesting, 2600 verter with 40k cooler, low lift cam, nnbs intake/TB, rails, injectors, possibly low lift cam, headers and tune. Thinking he has 3.73s in the rear. Give me some suggestions.
Old Jul 4, 2017 | 07:40 PM
robbielee's Avatar
Registered User
Default Cam for towing
Be very careful of the cam you choose, some make noise and I just don't like it. I'm using LS7 lifters K-motion push rods and double spring kit. Pretty good stuff but makes noise. An easy way to make more torque is to change out the rear gear and you can also go with the gear venders overdrive unit to keep fuel mileage. I've bored my 5.3 out to a 5.7 and raised the compression up to 10.3:1. It definitely makes more power but I still have the stock 308 gear and it needs to be changed out to make a big difference. There is so many better choices you can make that I didn't do but knew about. Stroke a 6.0 or 6.2 and get big gains! EASY TO DO, also raising the compression is another easy way to make power.
Old Jul 4, 2017 | 07:42 PM
robbielee's Avatar
Registered User
I'm also using the comp cams XR265HR
Old Jul 4, 2017 | 10:22 PM
robbielee's Avatar
Registered User
Whippel supercharger would help out (2.9L)! Also if he doesn't mind stopping for fuel more offten set it up for E85. 93 will work with the supercharger just make sure the tune is right. Oh one more thing if you can get at least a 4L80 trans for the towing. we all know the 60e's are weak and you don't want your old man stuck on the side of the road!
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
06 4.8
Jul 15, 2015 07:17 PM
07NBSChevy
20
Jul 8, 2015 07:27 PM
