5.3 For racing
Old Oct 19, 2017 | 01:46 PM
1FastBrick's Avatar
Custm2500's Rude Friend
In the LS1 world they have been when people tried to spin them hard.
While both rods are powered metal, The Later rods being beiffer retained their dimensions and resisted Bending much easier.
They have been reported to being spun in the 7K range and as much as 1400 Hp with forced induction. While the earlier rarely survive over 6500 and usually die anywhere from 500-700 range depending on application and RPM.
Old Oct 19, 2017 | 01:48 PM
1FastBrick's Avatar
Originally Posted by nathanl91
Ive been told this cam is pretty big for a 5.3...
Originally Posted by BudRacing
That statement makes no sense at all.
That is a Comp Cam Statement.
Old Oct 19, 2017 | 01:53 PM
BudRacing's Avatar
"That cam makes good, reliable power in a 5.3" Is what they meant. Syntax isn't always an engine builder's strong point.
Old Oct 19, 2017 | 01:58 PM
1FastBrick's Avatar
"That cam makes good power in a 5.3" Is what they meant. Syntax isn't always an engine builder's strong point.
Unfortunately the guy on the other line usually has no real experience with this specific application.
Back in the day, they told me the same thing about the 265 low lift cam that's just a little smaller than that cam.
They recomended a smaller cam with around .500 lift and like 208 duration or something on a wide LSA 115 or 116
Old Oct 19, 2017 | 03:42 PM
nathanl91's Avatar
so with truck intake, 4.8 pistons, cam mentioned, ported heads.. think i can get 400ish?
The goal is to make good power, without running 114 octane and having a 7500$ bottom end like my current 5.7 has..
Old Oct 19, 2017 | 04:14 PM
BudRacing's Avatar
I think that's a reasonable estimate. That intake may be the limitation out of that setup, but it could either be ported or swapped out pretty easily if you were to want for more.
Old Oct 19, 2017 | 05:20 PM
nathanl91's Avatar
My goal is a motor that will last, and be easy and cheap to maintain and rebuild when needed. 4-450HP is about what i have now and does well
Old Nov 11, 2017 | 02:34 PM
turboal1's Avatar
Default Int
Use the newer style truck intake manif,
it uses the larger 4 BOLT 87mm T/B
and you'll pick up more HP/TQ every where.
that cam looks good to me. IMHO i would
pick up a set of Gen4 rods if you will be spinning
that motor at a hi-rpm a lot. there fairly cheap used.
look for a set of 243 or 799 heads there about the
best stockers to run.
Old Jun 15, 2018 | 10:50 AM
nathanl91's Avatar
Alright guys, Reviving my own old thread, This project suffered from major delays but is finally on the verge of first startup..
The final specs of the motor ended up:
Comp Cams XR275
918 Springs
PRC 60CC stage 2.5 heads with 2.02 intake valves
Speed pro flat tops
Truck intake
Double Roller COmp chain
GMPP ported oil pump
Balanced Bottom end
Clevite Bearings
Sealed power rings
Patriot E-rod Headers ( chassis clearance)
FItech ULTIMATE LS engine controller
Walboro inline pump and corvette filter/regulator
summit stock lifters
Comp .080 magnum 7.3" pushrods
The final issue... Injectors? Am i correct assuming the stockers will in no way keep up?
Looking at the DW 44 or 60Lb/Hr direct fit truck injectors.
Old Jun 15, 2018 | 05:32 PM
FFDP's Avatar
Correct, stock 25lb/hr will not be enough.
44's will be enough and go 60's if you add small amounts of boost later on.
