5.3 pinged, LS1 or LQ9?
Old Aug 20, 2009 | 05:40 AM
lady3bglover's Avatar
Are you still running stock transmission?
Old Aug 20, 2009 | 05:53 AM
actually i'm on my 3rd transmission, stock one went out after my bad pinion angle caused the tail section to break and i drove a few miles to my friends house, causing the clutches to burn out 2 weeks after i repaired the tail. the second one was rebuilt with blue clutches and widened band and didn't last more than 10 months. My current transmission is a JR built 4L65E...
Old Aug 20, 2009 | 06:15 AM
Good deal. Hate to see you go through all that work and no transmission to support the new block.
Btw... I'm on my 4th trans. Went thru 3 GM trans, 3rd on crapped out 1 month before Ike. One week after Ike, new FLT 4L60E with 3400 Vig and Sonnax servos. Best decision.
Old Aug 20, 2009 | 09:07 AM
jdawg04 4.8's Avatar
LQ4 to my understanding had the weaker rods until later.
And spraying an LQ9 is fun i hit mine with a 200 progressive shot and made some nice power. Like mentionrd before LQ4 if F.I. is planned LQ9 if staying N/A.
Old Aug 20, 2009 | 09:22 AM
Wyttrash96's Avatar
I hate my cats
Originally Posted by 006rcsb
the lq9 would be great if you dont have plans for f.i. later, the higher compression it has over the lq4 is pretty nice. lq4's are more readily available and usually had for a little cheaper, they have a dished piston where as the lq9 has a flat top. as for the rods the 05 and up lq4's got ls2 rods that were stronger than previous years. the ls1 isnt a bad idea either, its only a few cubes short of a 6.0, i would go with that lq9 you found if it were me though. if you do plan on looking for a 6.0 lq4 though just make sure its at least an 02 or newer, the cranks were longer in 99-01 and they wont bolt to a 4l60.
Really? They won't bolt up to any 4L60E or just ones built after 01?
Old Sep 3, 2009 | 12:43 PM
ok guys just a lil update, ended up getting an LQ4 out of an 05 but now i'm feeling a little bit of buyers remorse for not getting an LQ9. I just feel like i'm really gonna miss out on the 20 extra horsepower but i guess it's all going to fit in my plans of either spraying a whole lot of nitrous or going with forced induction of some sort
Old Sep 3, 2009 | 01:13 PM
ap2002's Avatar
believe me you wont noticed the difference between LQ4/LQ9, my LQ4 runs with the best of them.... but if it bothers you that much, just mill the heads and youll have the same CR as the LQ9...
Old Sep 3, 2009 | 01:43 PM
that's helpful, it's still an upgrade from the 5.3, i just remember how my friend's truck would pull away from me with a cam'd LQ9
Old Sep 4, 2009 | 09:39 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Originally Posted by TexasSuperChevy
I keep reading otherwise... but if that is true I might get the one out of the 04 escalade I was looking at
In 05 up the LQ4 got the LS2 style rod.
supposedly the Lq9's got them in late 03 early 04
No one seems to be 100% but I guess there was a mid year design change at some point in 03 production of the LQ9.
1500 is alot of money for one. the only thing that is really different between an LQ4 and an LQ9 is the piston. LQ9 has the same floating pin flat top piston from the LS2 motor and the LQ4's will have a dish piston. early ones will be pressed and 05 up will be Floating.
Old Sep 4, 2009 | 09:43 PM
1FastBrick's Avatar
dont wory you did the right thing and probally saved some cash in the end.
