5.3 Cam question??
#32
#36
It is more the lobe angle seperation that gives you a quiet idle more so than the lift. A 118 will deffinately be a quiet idle but you can get close to stock with a 114.
That said, are you sure that is a Comp camshaft grind?? I thought those specs looked familiar when I was lookin on Lingenfelter's website the other day and hot dog what do ya know....Those are the specs of the GT11 camshaft. Oh and by the way, the intended application is for 350-427 cubic inch engines. Notice that the 5.3 (325 cubic inches) does not fall into that range meaning your power band will be even higher than 1600-6500. This means this cam is going to do nothing to help get that big avalanche moving off the line. Sure it will eventually pick up but by that time chances are you are behind by car lengths to a lighter vehicle and it wont matter. Just my 2 cents.
Originally Posted by Basool
Yea i know..but im thinkin of a cam thats not too harsh on the valve train but gives me good under the curve power..with a choppy idle..
#40
