5.3 block convert to 5.7
Old Jul 3, 2018 | 06:06 PM
MrHorsepowerLSx's Avatar
11 Second Club
You will be able to drive it depending on if you put an aggressive cam in the motor, and change the injectors.
Best way to approach the situation would be to do whatever you plan with the motor, and change the injectors at the dyno before your tuning begins.
If you are more concerned with extra cubes just buy a running 5.3 and build your 4.8 when the funds allow. A stock 5.3 will have more CI then putting 5.7L slugs in your 4.8
And as a bonus you can use the 5.3 rotating assembly when the 4.8 gets bored and you will have a true iron LS1
Old Jul 4, 2018 | 09:55 AM
noobnoob's Avatar
Default E85 Injectors
Are E85 injectors a bolt on upgrade? My truck is a stock '05 and I run across used sets of E85 injectors pretty often so they would be an obvious choice for me.
Old Jul 4, 2018 | 11:17 AM
kbracing96's Avatar
No, They use a different pigtail. You would have to get adapters or cut and splice your harness for the correct pigtail.
benpimpin1
Jan 12, 2012 08:53 AM
8100hammer
May 15, 2005 10:12 AM
lifted99GMC
11
Nov 26, 2004 11:46 PM
Hit Man X
Jun 3, 2003 02:52 AM
