5.3 to 6.0 mods + turbo
well i think we have decided on the motor for my 1500 silverado. Here is a list of what LME is going to do for us. Around 700chp without turbo. Engine will love to turn alot of rpm's
My only questions are what trans. and rearend will hold up to this power?
2.What manifold and tb to use? was looking at the wilson manifolds and tb
3.Does this engine look good to everyone, or is there any changes anyone see i should make to it.
After the motor is in we are getting a sts turbo with the GT70 turbo, meth injections and all the goodies.
The list.
408 Iron LS1 408" Iron Balanced, blue printed and assembled short block.
Callies 4.0" crankshaft, Lunati 6.125" pro billet rods, Wiseco
4.030" custom forged pistons w/ lateral gas ports, Federal Mogal
152M main brgs, Clevite cb663 H rod brgs, Dura Bond cam brgs,
ARP main studs
ETPG3 cyl. heads ET Cylinder Heads ETPG3 heads.
350+ CFM int. 240CFM exh. @ .700 lift. Parts: Ferrea 2.08"
1.600" exh. valves, Comp. Triple springs, Xceldyne super 7
titanium retainers, machined locators and viton valve seals.
LS1 solid lifters Lunati solid roller lifters
Solid roller cam LSM Custom Solid roller camshaft
CV 3/8 push rods CV Products 3/8 pushrods
Timing chain Roll master timing chain nitrited gears and torr. bearing
LS1 Oil Pump LS1 ported Oil Pump
Jesels LS1 Jesel Pro series adjustible Rockers (LS1)
Install splayed caps Install all 5 billet main caps/ Line bore and hone
LS1/LS2 billet caps LS1/ LS2 Billet Main Caps
LS1 studs 1/2 inch ARP 1/2 LS1 head studs
LS1 copper gaskets SCE ICS Titan copper head gaskets
LS1 1/2 studs Machine block and heads for 1/2 studs
Oil pan LME Sheetmetal LME oil pan
LME custom oiling LME custom oiling
Remote oil filter Remote oil filter housing, oil pressure regulator, filters, fittings.
LS1 pick up tube LS1 custom pick up tube for sheet metal pan
Any other coment is ok also, or rec. Thanks for the help.
Att. is a pick of the truck we are doing the work on. Thanks for the help
The list.
ARP main studs
Well Im putting a forged 408 in my ecsb Z71. We will always have traction you wont. 2wd sucks. Plus it hurts peoples feelings alot worse when its a big *** truck, I have personally hurt a few cocky car guys feelings.
Thats what i am talking about. Plus i have had this truck for about five years and it is like my baby or something, never going to get rid of it, it is paid off, and i am just paying insurance now.
What type of manifold and TB do i need i have been looking at this one along with the fuel rails. http://wilsonmanifolds.com/lsx_espanol.html
Still have not made up my mind on the tranny, i was looking at the 4l80E but i read somewhere where the highest shift rpm is 5200, the motor we are building will be turning a little more than that.
Tin Foil Hat Wearin' Fool
You can shift it way past that. 5200 is stupid. Third gear may be limited to that not sure I think moregrip was complaining about something with that rpm. But third in an 80e is going to be like 125 and you dont want to go any faster trust me with that lifted truck minehas been up to a little over 130 at stock height and it was hard to control to say the least. I dont know why that intake says wilson on it but the fast system is a good system pm 2toneblown he ahs one on his 408 with a turbo he can give you a personal experience as to how well it works.
Im guessing for a built 80e, the parts to converter it, the engine, and turbo will probably caost him close to 12 grand or so. My built 60e was 3grand and it bolts right in, my 408 will cost me 4grand by the time its all said and done and his engine is going to be alot more expensive than mine plus the cost of the turbo stuff and the parts needed to put the 80e in his truck.
Hey, i think the engine was around 13k from LME, the turbo with intercooler, meth. and the GT 70 turbo is around 6K or so, then the trans, which i am not sure on it yet and rearend. Then a few more K, for elec. fans, maf sensor, headers, injectors, manifold and the smaller picky things. We are going to try to get 8-900 CHp out of it. We will keep trying till we do.
Would a manual or auto trans. be better for this, i have the center console in my truck, (everyone that has a chevy like mine knows what i am talking about) with the cup holder, i was wondering if anyone had changed it over to a manual trans and put in a sports car style shifter where the cup holder is, i dont know if this is doable but i was thinking it would be nice to have.
