5.3 to a 383?
Old Sep 5, 2007 | 08:50 AM
silver-mod-o's Avatar
Hunt&Fisherator
the wristpins in stroked motors are moved to accomidate the extra stroke.
Old Sep 5, 2007 | 09:01 AM
Phantom's Avatar
11 Second Club
i thought it was no problem to make a 5.3 into a 383? am i reading this right that the only "safe" bore is to LS1(5.7) status?
Old Sep 5, 2007 | 09:09 AM
Hunt&Fisherator
I definitely wouldnt say its "unsafe" if W2W says its ok, I'd trust them and go for it. the biggest issue would be the thinner cylinder walls if you were increasing the cylinder pressures with either a lot of boost or a lot of bottle.
Old Sep 5, 2007 | 09:13 AM
Phantom's Avatar
11 Second Club
are the cylinder walls the same thickness when you go from an ls1 to a 383 as they are if you 5.3 to 383?
Old Sep 5, 2007 | 09:16 AM
Hunt&Fisherator
you'd have to re-sleeve the aluminum block to do that much overbore if I'm not mistaken. thats where the LS1 block gets spendy....
Old Sep 5, 2007 | 09:18 AM
Phantom's Avatar
11 Second Club
surely there are some guys on here who have gone 5.3 to 383 and are sprayin it...anybody?
Old Sep 5, 2007 | 09:25 AM
kbracing96's Avatar
You bore a LS1 .010 and put a 4" stroker crank and appropriate pistons in it to get a 383. You can do the same thing with a 5.3, only your boring it .134 which it can handle just fine there are at least a half a dozen 5.3 on the board that I know of that have been bored out to LS1 bore sizes and I have never heard of any of them failing or cracking the cylinder. Most of them around here are also FI motors, Like BlownChevy.
Old Sep 5, 2007 | 05:05 PM
Bo185's Avatar
Why not leave the bore alone and just use the stroker crank and have a 360! Lol... 6.0L the expensive way!
Old Sep 5, 2007 | 07:36 PM
NegraRCSB2X4auto's Avatar
exactly how expensive would this be...
Old Sep 5, 2007 | 08:33 PM
IMD's Avatar
IMD
Banned
if you're talking stroker stuff, youre going to have to buy pistons, rods, and a crank no matter what block you put them in. in my opinion, theres no point spending the money to bore your 5.3, then buy the rotating assembly to make a 383. if you're going to buy all this stuff, why not put it all into a 6.0 block and have a 402 or 408, for exactly the same money. theres an easy 50 ft.lbs and 50 hp just in the displacement difference. theres really no good reason to make a 383 out of a 5.3....at least not cost wise. theres no cheap or half assed way to do it. either spend the money on a turbo kit, or on a 6.0 stroker, and stop fu*&ing around.
