400rwhp 5.3l?
Old Sep 10, 2007 | 09:31 PM
closet red neck's Avatar
Wait........I don't want to get into an arguement with you guys. I'm gonna loose until I get some hard numbers. With what I know now, I'll make up some lost time at the track this go around.
James
Old Sep 10, 2007 | 09:39 PM
silver-mod-o's Avatar
Hunt&Fisherator
Lance put down 340/340 with his truck last time on the rollers...
he puts every single Hp to use on the track for sure
Old Sep 10, 2007 | 09:48 PM
Yes he does and his truck runs great!!
James
Old Sep 10, 2007 | 10:07 PM
RandomHero's Avatar
Originally Posted by closet red neck
Oh Mark, if you think that it is silly, let me take you for a ride and show you how a 4WD truck can spin in 4hi, 60' out of the whole. It'll lay two black marks in 2WD for 450' or until you loose it.
James
James my comment was meant say that it's silly to spend that much money on a 5.3L just for a dyno number. I have every intention of keeping my 5.3L in my truck. I've seen yours pre-cam, Blue Cajun, ap2002, silver-mod-o, txsilverado(pre ls1), and tons of others are my truck's "role model" so to speak and they all run/ran 5.3Ls and had amazing times.
Old Sep 10, 2007 | 10:27 PM
Oh just for numbers.........I see. Well I'm after ET. But too get the ET you have too have the HP and TQ to do so. I'm shooting for a 12.5 next time @ the track. My question for you guys is if I run a 12.5, should I be putting down lets say 385hp or more to the ground??? Sorry for hijacking this thread but you wanted to see what I takes to get 400hp to the ground. Also to, I hit 385hp to the ground while going through a t-case.........I should be seeing 21% drivetrain loss. So a 2WD would see a 19%????? I don't know..........
I'll post up some new ET's and dyno numbers later this year.
Good luck with 400HP to the ground!!!!
James
Old Sep 10, 2007 | 10:35 PM
RandomHero's Avatar
James
See that's partially my point. BlueCajun only dynoed at 340/340 when he ran the 12.5, and TXSilverado broke into the 13's with an extended cab and he dynoed at only 277 rwhp. In theory if BlueCajun was putting down 400rwhp then he should be in the 11's n/a
Old Sep 10, 2007 | 11:39 PM
nxpress03's Avatar
Well I think it has to do with mother nature depending on where you are at. Like am in oklahoma and I put down 455 on the spray and went high 11s, on motor I went mid 13s and I put down 350hp na. Where you are located matters as far as air density goes less humidity means you are going to put down good numbers and good ets so you can't really go off of some of this guys. Good air helps this trucks alot! that well tell you why txsilverado went 13a on 277 in a extcab which is still hard to take in.
Old Sep 11, 2007 | 12:04 AM
IMD's Avatar
IMD
Banned
well i put down 9374 rwhp and i ran a 4.38 @ 792 mph. :ugh:
Old Sep 11, 2007 | 02:16 AM
PappyDan's Avatar
Tribe Shaman
now i know im drinkin tonight but how many have you had
to lay down these kind of numbers.
Old Sep 11, 2007 | 01:44 PM
Hunt&Fisherator
musta been standin in the brakes at the 1000 ft mark LOL...
