243 milled 59cc...cr ? lq4
Old Jun 9, 2010 | 05:52 PM
Nicksilverado's Avatar
Originally Posted by Wheatley
Got your Pm,that is correct!!
i sent you a pm? and thanks!
Old Jun 9, 2010 | 05:59 PM
Originally Posted by LS1FREEK
An ls6 head has 64cc combustion chambers, right?
yes they are exactly 64.45cc
Old Jun 9, 2010 | 07:52 PM
MPFD's Avatar
11 Second Truck Club
.020" will get you a 62 cc chamber, so just a shade less then that. I've got a .020" shave with a .040" cometic gasket and I'm just under 11 to 1...
Old Jun 9, 2010 | 09:58 PM
skolman91's Avatar
different question but along the same lines, whats the max you can mill 243s or any LS head for that fact? ive searched alot and found one or two that have done .050 & .055 on 862s and also mentioned anything past that might run into intake fitment problems, but then ive read the plastic intake is pretty forgiving..? so who knows of actual info and not hearsay about max milling and fitments..?
Old Jun 9, 2010 | 10:02 PM
MPFD's Avatar
My buddy went .060" on a set of L92's. I've heard of .045-.050" on cathedral ports.
Old Jun 10, 2010 | 12:32 AM
max1's Avatar
Banned
I did 0.030- on some 243's- and dint have any intake fitment problems ' I might. Go- 0.040 or more if fitments permits it.
Old Jun 10, 2010 | 08:42 AM
hirdlej's Avatar
Just make sure if you have you guy mill the heads, that he mills the same amount of material off the intake side of the heads, your intake will fit just fit. Hacking .050+ material off a head though with any sizable cam I'd be worried about PTV clearance unless you're willing to flycut the pistons
Old Jun 10, 2010 | 11:36 AM
Tootall's Avatar
umha . . . that's a negative . . .
If you're getting your heads milled, the head side is the only side that gets milled.
Old Jun 10, 2010 | 12:33 PM
MPFD's Avatar
I didn't say it didn't need custom built diamond pistons But it actually has some compression on what was a lq4 block... The original plan was to fly cut, but it still didn't clear. Which is where I got my short block and the one I owned (that was at the machine shop) got punched for the diamonds.
Old Jun 10, 2010 | 01:37 PM
fastrt's Avatar
I cut .050" off my 862's. had a couple braket issues, but no big deal. had to bolt the intake down nice and slow, and in a circle pattern, then tq to spec. depending on the cc of a lq4 piston, it's either 10.75-10.8 to 1.
