Are 243 heads worth it?
Old Jan 4, 2012 | 05:00 PM
Cakes's Avatar
Default Are 243 heads worth it?
I am planning on installing a 2005 LQ4 in my truck shortly with an EPS 222/226 Cam and the mods in my signature. Is there much to gain from going from the stock 317 heads to stock 243 heads? If not, I will just save my time and money for a set of ported ones.
Thanks for your help!
Old Jan 4, 2012 | 05:09 PM
Dezert1500's Avatar
No they flow the same, the 243's just have more compression. Have Richard at WCCH run his stage 2 port program on the 243's and then you'll gain.
http://www.proheads.com/WCCH%20LS6.html
Old Jan 4, 2012 | 07:27 PM
kr1s's Avatar
Not trying to TJ. but would these heads on a 5.3 drop or raise compression?
Old Jan 4, 2012 | 07:32 PM
Chevy_King1500's Avatar
stock they would drop, you have to mill them .030'' to bring compression back up.
Old Jan 4, 2012 | 08:04 PM
dmelvin's Avatar
243's would drop compression -- 317's would drop compression... a lot.
Old Jan 4, 2012 | 08:16 PM
Jake99's Avatar
I think they are are worth it, you can get them for 300 bucks and they will gain you about 20hp, the extra compression helps in out quit a bit, you will go from 9.5-1 to close to 10.5-1
Old Jan 4, 2012 | 08:24 PM
LsxCody's Avatar
I say they are worth it too, if you can find a set cheap.
Old Jan 6, 2012 | 08:34 PM
Killer5.3's Avatar
Yep. 317 is a 72cc chamber and 243 is 64.5cc chamber.
Old Jan 6, 2012 | 08:38 PM
They drop compression on a 5.3 but he is installing them on a 6.0 so they would raise compression.
Old Jan 6, 2012 | 10:24 PM
kr1s's Avatar
I wanna drop since i wanna go FI
