228r cam nitrous friendly?
Is the 228r cam nitrous friendly ?
Want to run 150 shot.
And can someone explain the 114 ?
Let's say compared to a 110 or 112 lobe
5.3 silverado
228/228 cam, 114 lobe
FBO
Cnc heads
102 fast intake
3200/ 6spd
5.3 silverado
FBO
Cnc heads
102 fast intake
3200/ 6spd
It would respond quite well to nitrous. This link explains how LSA effects performance really well. Technical Specs & Information
Basically, lowering LSA moves powerband down and gives you a choppier idle. Raising the LSA reverses that effect.
every application is different. 98% of the trucks on this site are cookie cutter builds (including mine, and sorry if it hurts your feelings) start swapping major components in the top end like heads and intake styles and things change big time. there's nothing special to the bottom end of our trucks that typically spray less than a 150 shot 90% of the time.
