220/224 – 580/581 – 115 cam install
Old Nov 26, 2005 | 06:34 PM
  #31
Originally Posted by bud8fan
allen has a superflow dyno...allen has installed this cam in a few other trucks w/ good results as well...not running a boost guage with the radix...only on the dyno to see where the numbers were...
SuperFlow will give similar results as a Mustang,both apply a load while Dynojet estimates hp/tq through inertia.So the numbers are still very good.If you are getting 20 MPG the motor is producing good vacuum.
Old Nov 26, 2005 | 06:59 PM
  #32
1SlowHoe's Avatar
Destroyer of Transmissions
Is this true of all Dynojets? The one I use has some kind of eddy current load that they put into it. It is supposed to simulate street conditions. This dyno is fairly new so maybe its an upgrade?
Old Nov 26, 2005 | 07:15 PM
  #33
I think are right,that a current load is available on Dynojet's newest dyno,but all of the older units were straight inertia dynos.The Dynojet I used was not capable of adding a load.
Old Nov 26, 2005 | 10:29 PM
  #34
gonzo 6.2's Avatar
hehehe...i would have loved to get you a rev but needed some help that i didnt have...coudda just put the camera on the ground i suppose oh well...next time....
Let me give you a little mechanics tip.No need to set it on the ground.A milk crate or a log or a card board box it could have been set on while you pushed the camera button,opened the door hit the gas ran it up to say 6k a couple times walked back and clicked off the camera.Pretty simple,guys with far less trucks have been able to GET'R DONE.
Just flik'n ya
Sounds great!
Old Nov 26, 2005 | 10:35 PM
  #35
bud8fan's Avatar
i know..i know...she was kinda cold at the time...i just walked out of the house and cranked her up and got some vid...shoudda waited till it warmed up a bit....
Old Nov 27, 2005 | 10:34 AM
  #36
What is the intake centerline on your cam?I'm tring to compare the numbers with some other cams from Comp and Lingenfelter.
Old Nov 27, 2005 | 05:56 PM
  #37
bud8fan's Avatar
you have a pm
Old Nov 27, 2005 | 06:03 PM
  #38
slamedboosted&shaved's Avatar
what else did u ave to put in when u did the cam did the cam need any value train items to support it
Old Nov 27, 2005 | 08:43 PM
  #39
bud8fan's Avatar
comp harden pushrods and 918 springs...thats it.
Old Nov 29, 2005 | 04:17 PM
  #40
how much hp did u get from the cam install?
