Hey everyone, this is my first post in this group so go easy on me if I screw up or if I shouldn't be posting here.
I'm rebuilding my 5.3 and I'm hoping someone knows if this cam will still allow me to pass CA emissions. The technician from Comp said I should be fine. I'm just looking for confirmation.
Here are my modifications,
5.3 boring to 5.7
Ported intake manifold and throttle body
Stock 799 heads and valves, milling them for a bit higher C/R
Underdrive crank pulley
Headers & Flowmaster Super 44
3.08 to 4.56
Blackbear tuned
That's a relatively small cam even for the increase in displacement and likely you wouldn't notice the difference in emissions even if it was put on a sniffer...
Thanks for the input guys. Being that both of you have referenced that cam as being small, is it even worth installing or should I move up to something larger? That's what the tech from Comp recommended when I told him that I'm restricted to emissions testing, I just want to make sure I'm putting something in that's worth the time and money.
