2010 Silverado 5.3 build HELP
Old Jul 31, 2018 | 04:55 PM
FFDP's Avatar
Both are way too large for stock stall. Notice how they also say they are made for the L99 engine in the camaro, not exactly ideal for a heavy *** truck.
This is also where you gotta remember that you have VVT. So you can either keep VVT or delete VVT.
Stick to something like I already said, 212/218 or close to that.
Old Jul 31, 2018 | 10:39 PM
Jacob_pringnitz's Avatar
Registered User
do i want high lift or low lift
Old Aug 3, 2018 | 07:22 PM
Registered User
or what do u suggest
Old Aug 3, 2018 | 08:05 PM
FFDP's Avatar
Low lift is just fine on a 5.3.
Old Aug 3, 2018 | 10:14 PM
Registered User
i know i need diffent push rods but can i use stock valve springs
Old Aug 3, 2018 | 10:39 PM
FFDP's Avatar
No, needs stronger ones.
Old Aug 7, 2018 | 04:42 PM
Registered User
would i be sacrificing power if i stayed with stock headers and y pipe with cats
Old Aug 8, 2018 | 02:41 PM
madmann26's Avatar
Yes. Headers move the power band up in the rpm range.
You can do a PAC-1218 spring and reuse your stock retainers/seats/locks.
If you do a double spring, you have to change it all out. Just means more money.
Old Sep 3, 2018 | 07:45 PM
Registered User
what woud be the best choice
usining stock exhaust manifold and have the cats removed and just replace the muffler
replace with long tubs and off road y pipe with a new muffler'
i just want to keep it quet ish with the new cam so would the cast manifolds keep the nosie down or woud they cut the flow and sacrifce alot of power
Old Sep 3, 2018 | 07:52 PM
Bad01z71's Avatar
Gonna sacrifice. One would definitely benefit from LT's especially with an aftermarket cam.
