2007 chevy silverado 4.8 cam
Old Mar 15, 2018 | 06:09 PM
Tyler_pevehouse's Avatar
Registered User
Default 2007 chevy silverado 4.8 cam
Hey guys i am wanting to buy a cam for my 4.8 but dont know what kind of cam to get its my dd but i still wanna go and get the lope any ideas??? I have headers taylor wires and a volant air intake plus a wideband and whole new exhaust i dont want to break the bank cause i am only 18 and if yall could send links that woild be great yall😀
Old Mar 15, 2018 | 06:45 PM
FFDP's Avatar
It's kinda pick one or the other most of the time.
Do you just want lope or do it want it to perform great with the stock torque converter and have less lope. Though with an aftermarket exhaust the "lope" will be more pronounced because the lack of things muffling the sound like cats/resonator/factory muffler.
Look at texas speed and brian tooley racing for cams. You will have to stay relatively small with a stock stall torque converter. Something around the 212/218 range or similar is always a good size camshaft. Then tuning is the key to making it run good.
Old Mar 15, 2018 | 10:31 PM
Registered User
i have found this what do you think with the stage 3 cam and ls6 springs?https://www.briantooleyracing.com/btr-truck-cam-kit-with-your-choice-of-springs-and-camshaft-36516.html
Old Mar 15, 2018 | 10:42 PM
FFDP's Avatar
BTR says the stage 3 works far better with an aftermarket high stall converter.
Stick with the stage 1 or 2 cam if you are keeping with the stock stall and LS6 springs will work fine.
Old Mar 19, 2018 | 05:19 PM
Tayj6's Avatar
I highly recommend the cam motion drop in cams. Stay low lift if you want to keep it cheap and use stock springs. You need to have it tuned regardless of which can you install and the “lope” can be tuned in if you really want it. Any cam that is going to work well with a stock converter isn’t going to naturally lope.
Old Mar 23, 2018 | 03:12 PM
B00sted2007's Avatar
I know trickflow makes a 216/220 .560/.560 114lsa camshaft. It would be great for a daily driver, plus it’s cheaper than most and you could use ls6 or Ls3 valve springs along with stock pushrods. With this cam you would only have around $300-$360 in a complete cam swap, that’s new Ls3/ls6 springs and all.
monchis
Nov 9, 2011 09:48 PM
Phatchevy
Sep 20, 2006 07:31 PM
