10.1 compression with 87 octane bad idea or not???
Old Feb 22, 2012 | 09:15 AM
  #21
yurs78's Avatar
Sorry I was off, the stock cc's are 61. It looks like dropping 3cc's is going to raise compression almost a full point. (.89). You will be about 10.38:1 when you're done, on the high side for 87 but still possible.
Love to see some dyno results, thanks again!
Old Feb 24, 2012 | 04:25 PM
  #22
DR132's Avatar
How much cam are going to run? This will affect how much compression you will be able to get away with, a hotter cam will bleed more cylinder pressure allowing a higher compression ratio without detonation...that said, 10.anything to 1 isn't really that high, especially for an ls motor, so pump gas shouldn't be a concern.
Old Mar 6, 2012 | 04:31 PM
  #23
topher67's Avatar
Do you have any ball park idea how much hp & tq will be gained at the motor with a .8 compression jump?
Yall are right on the 93 octane. My friend and I just took his dodge hemi to taos for the weekend. 14 mpg at 70-75 with 87 octane & 16.3 mpg at 80-85 with 91 octane. We actually saved $4 a tank with the extra 50 miles we could go on a tank.
I think at most it was $8 more.
bgray
Aug 29, 2015 11:27 PM
cosb
Aug 24, 2015 09:08 PM
Fast86z
Aug 23, 2015 12:35 AM
primal1
Aug 22, 2015 07:03 PM
89sierra
Aug 19, 2015 07:13 PM
