06 L33 Questions
Old Jan 21, 2007 | 07:47 PM
468BIGBLOCK's Avatar
Default 06 L33 Questions
I Have A 06 Silverado With The Vin Code B The L33 Option I Know That It Has The Aluminum Block, I Heard I Has Ls2 Heads, What Is The Horse Power And Torque Ratings? Is The Cam Different, What Is The Aproxx. Weight?/thanks!!!!!!!!!!!!!!!
Old Jan 21, 2007 | 07:48 PM
nightrunner's Avatar
Mr. Obvious
its an all aluminum 5.3 with 310hp not sure on torque
Old Jan 21, 2007 | 07:54 PM
joshluther's Avatar
The motor is 75# lighter than an iron block. I don't know about the cam. The heads should be 799 casting. The motor has flat tops.
Old Jan 22, 2007 | 10:57 AM
SBTork's Avatar
yes the heads are the same as they used on the LS2.
Old Jan 22, 2007 | 11:28 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Cool, I knew I had different heads but didn't know which ones. Is 799 the correct casting #? The chamber has to be quite a bit smaller though, right?
The cam is different too but I dont know the specs off-hand and yes, the L33's have flat top pistons.
I heard the block is closer to 100lb lighter?
Old Jan 22, 2007 | 11:38 AM
Moddoo's Avatar
Welcome to the L33 club.
There are not too many out there.
These engines with the better heads, and higher compression, respond well to mods.
You're a couple steps ahead of the LM7 guys.
Here is some good info for you.
https://www.performancetrucks.net/fo...&highlight=l33
Old Jan 22, 2007 | 09:11 PM
Thanks Guys!!!!!!!!!!!!
Ws6ickness
Feb 5, 2016 02:42 PM
JordanH
Dec 25, 2015 08:32 AM
spooneralmighty
Sep 11, 2015 02:28 PM
chevstang421
Sep 10, 2015 09:16 AM
carid
Sep 10, 2015 09:07 AM
