.04 or .03 cometic gaskets. Which would you choose?
Getting ready to do my cam swap in a few months still scraping up the parts
I wanted to bump compression up with head gaskets.
Stock 5.3L 61.15 cc heads .053 gasket 9.49 compression
With .04 gasket 9.76 compression
With .03 gasket 9.98 compression < would this one be 2 thin?
If stock pushrods are 7.4" with .04 gasket would I need 7.3" rods and .03 need 7.2" pushrods
Not 7.3" pushrods, that's a tenth of an inch, not a hundredth. If you didn't pull the heads and mill them, 7.4" pushrods would probably still work. If anything, 7.375" pushrods for a .030 head gasket. That's 25 thousandths shorter pushrods and a 23 thousandths thinner head gasket.
Baltimore Whore
Unless you are going back to stock size gaskets I would take a measurement with a checker. However I did not and had .020 milled off my heads, stock gaskets, used a 7.4 push rod with out any issues. However I did rotate the engine over after the install to make sure the rockers were riding on the tips in a happy spot. The .03 gasket is what I would go with.
For us, we sell the tool to ensure the customer gets a correct length rather than having us guess for them.
Yes, we have some setups that 90% of the time end up using the same pushrod, but there is that 10% out there with the same setup, that will end up using a different pushrod length (could range from the variances in block decks from GM, to a customer not knowing that his "stock" heads were milled, etc., and etc.).
zblee
11-11-2015 12:41 AM
SlvrSierra4.8
10-01-2015 09:39 PM
