03 Silverado Cam Help
Old Dec 11, 2010 | 10:00 PM
bmd_CL's Avatar
Default 03 Silverado Cam Help
http://www.texas-speed.com/shop/item...d=175&catid=49
what do yall think?
i was thinking of the 224 112 lsa but idk...the truck is a 2003 rcsb 5.3, no towing... mostly daily driving but some racing (both street and track). i will have pacesetter lts and ory and a cold air and black bear tune before the cam and hopefully stall not to long after i get the cam. what do yall think?
THANKS
Old Dec 11, 2010 | 10:18 PM
black04's Avatar
I would do the stall first and then the cam.
Old Dec 12, 2010 | 12:23 AM
bmd_CL's Avatar
why stall first? jw...would it hurt anything if i put the cam in first? or could i go to a smaller cam? i wanna do a stall eventually but want cam first...does anyone know of any other cam packages?
Old Dec 12, 2010 | 01:38 PM
jrmchevyman's Avatar
it would be a turd down low with a 224r and stock converter, as you get to about 3000rpm it would then haul pretty good.
You gotta pay to play and if you are not serious about getting a stall soon Id go lower on the cam like a 212/218 or something similar. The stock converter would run decent on that cam (212/218).
Old Dec 12, 2010 | 05:01 PM
bmd_CL's Avatar
Where would i find a good quality cam package in that size? Thanks for the help... I dont think i wanna go with a bigger stall for a while is why im thinking about a smaller cam...
Old Dec 12, 2010 | 05:28 PM
bmd_CL's Avatar
Ok, well since im not wanting to buy a stall for a little while, what about this
http://www.thunderracing.com/catalog/cart/?action=added
Old Dec 12, 2010 | 05:32 PM
the shopping cart does not work for us but texas speed has what I was talking about in a package deal.
Select the cam package #1 for your truck then select the Options and scroll down and you will see it at the very bottom of the list 212/218 HIGH LIFT camshaft. Then select your lsa I would not go lower than 112lsa. All you need with that cam is the pac1218 beehive springs.
Old Dec 12, 2010 | 05:38 PM
carolinaz71's Avatar
tsp 220 wasn't that bad without the stall, even better with it thou
Old Dec 12, 2010 | 09:55 PM
bmd_CL's Avatar
carolinaz71, what truck did you have with the tsp220? What mods also?
Old Dec 12, 2010 | 10:05 PM
Bigschwerm's Avatar
The Vinci Trucker on a stock stall is great .... a 2600 stall later on would be a great setup
