Truetrac Install
Old Jul 11, 2017 | 05:38 PM
madmann26's Avatar
Originally Posted by PSM
Is it stupid to reuse the axle seals if the truck only has 25k miles on it?
Only reason not to is if you think you messed them up by pulling the axles out about 4 inches.
At 25k, that's barely broken in. My 06 still had the stock seals in it when it was rebuilt a couple of months ago at around 193k.
Old Jul 18, 2017 | 08:49 AM
PSM's Avatar
PSM
I found out my local Napa rents a dial indicator and they also rent a case spreader. Should I get the case spreader to preload the carrier bearings or just tap in some extra shims? If so how much do I "spread" the case?
Old Jul 18, 2017 | 04:57 PM
07Softail's Avatar
don't use a spreader just tap the shims in.
RT
Old Jul 18, 2017 | 05:50 PM
GR8TALK's Avatar
Yep tap them in. Spreader not required.
Old Jul 18, 2017 | 08:15 PM
PSM's Avatar
PSM
RT
Oh, ok. In reading how to's some recommended spreading the case to ensure you get enough carrier bearings preload, especially on higher how vehicle to prevent ring gear deflection. With 650-700hp going to it I thought I'd need the extra preload, but looks like I don't!
