Trans shudder
Old Aug 30, 2020 | 04:59 PM
Go5.3tt06's Avatar
Default Trans shudder
17 gmc Denali 6.2 had Issue with trans shudder. It was in 2 years go. Dealership have tech bullentin said needs to flush trans fluid to stop the shudder. After serviced that. Fine for 2 years until now I feel trans shudder again. Need to go dealership to have trans machine flush or should I do it myself drain old fluid off then put in new one?
mobil lvp trans fluid. Which your suggestion. Let shop do flush trans ? I don’t want change torque converter. I was hope flush can help? Need your feedback k.
Old Aug 30, 2020 | 05:37 PM
Bgbldodge's Avatar
Gotta drop the exhaust to drop the pan.
Old Aug 30, 2020 | 06:50 PM
Go5.3tt06's Avatar
What about flush machine
Old Aug 30, 2020 | 08:46 PM
FFDP's Avatar
A fluid exchange machine would work just fine to replace all the fluid with new stuff. I think GM says that you need like 20 quarts when they do it that way.
Old Aug 31, 2020 | 03:46 PM
00pooterSS's Avatar
Just flush it again, with the same new mobil fluid.
Most likely the additive package is starting to break down and that's why you're feeling the shudder again.
Your trans likely takes around 12 quarts, dropping the pan and filter will only get about 4 quarts. I have a 6L80 and when I drain the pan I get 4 quarts. That's why the flush is so much better, it exchanges all the fluid.
Old Sep 1, 2020 | 04:08 PM
Atomic's Avatar
I have a gauge for that
Took my 18 into the dealer a few weeks ago for this also, they told me they used 30ish quarts to flush it 3 times then fill. Not sure if thats true or not but the issue was fixed when I got it back. Also heard if you update the tune and up converter pressure the problem is fixed permantely.
Old Sep 1, 2020 | 05:43 PM
00pooterSS's Avatar
That sounds about right. I've heard that they do use up to 30. I did that on mine as well but a different deal.
I bet the new fluid along with the updated programming/tune is a great fix.
Old Sep 15, 2020 | 09:56 AM
Go5.3tt06's Avatar
Update flush done and its back normal. Need tune transmssion bad I dont like lack of time response throttle and shift point.
Old Sep 15, 2020 | 12:24 PM
00pooterSS's Avatar
Reset trans adaptives and drive it normal for a few days and see how you like that. You'll need a good scanner to do it, or take to dealer and ask them to reset adaptives, or disconnect battery over night (i've always used a scanner to do it, I assume disconnecting the battery for a good while will do it but I haven't tried it)
Those transmissions shift great but the adaptives may be funky right now since it was trying to adapt to old fluid. Now that it has fresh fluid it needs to relearn shifts etc.
And from what I understand, it's best to leave the trans tune alone and just up the shift points and take the minimal amount of tq management out in the pcm tune and they shift great. I may be wrong but I believe that's what most tuners are doing for good shifts and trans longevity (mostly leaving the trans alone)
Old Oct 13, 2020 | 12:09 AM
JCunningham's Avatar
the dealer will do it 3 times for free then replace converter. it takes 20qts of the new Mobil 1 HP. then ya do trans clutch relearn. anyone with a HP MPVI2 can do it.
