Procharged truck update
Old Nov 30, 2016 | 08:23 AM
  #71
allenp's Avatar
Idk yet, maybe a th400 maybe a 4l80 lol
There isn't a harness to do a 4l80 swap in these newer trucks yet so I'd have to run a separate transmission controller.
Another problem is the highpressure side fueling, there are new injectors/highside pump that is out but they are crazy expensive lol
Old Nov 30, 2016 | 08:29 AM
  #72
weazleburger's Avatar
Love this truck, it's extremely impressive!
Old Nov 30, 2016 | 09:24 AM
  #73
Vortec350ss's Avatar
3.5 pulley with what diameter lower? If its OD and its 8.25 you are right on the edge of max blower speed of 64000 depending on shift points. I wonder if you're seeing belt slip.
Just looked back at some pics... I bet your intake is choking it up top a little too.
Old Nov 30, 2016 | 10:46 AM
  #74
allenp's Avatar
Procharger said we are overspinning the blower by 900rpm lol
Next 2 mods are a Holley hi ram intake, and having 2" headers/4" exhaust made. I want to do an f series but there is no 8 rib option for these newer trucks, so I'm planning on adding nitrous after I get the motor done
Old Dec 1, 2016 | 05:17 AM
  #75
wuznme's Avatar
Guy over on gm-trucks stated he just ordered IW 8-rib for his 6.2L
CPR has a low side kit that will help feed the LT4 high side, just south of $2k.
Old Dec 1, 2016 | 12:03 PM
  #76
allenp's Avatar
I have the cpr lowside, and my highside is already maxed out because I'm on e85 that's why we had to add meth! I'm going tovlook into that 8 rib kit right now thanks!
Old Dec 8, 2016 | 07:45 PM
  #77
07Softail's Avatar
The Lingenfelter pump is $1495 and the friggin injectors are $495ea. ****** crazy *** money there!
RT
Old Dec 11, 2016 | 08:43 PM
  #78
grey matter 04's Avatar
13 Second Truck Club
Similar to your setup but an Xcab 5.3.
D1 stock pulley making 12psi at 6900rpm. Has a very small cam with a lil port work on the stock heads and a meth kit and nitrous kit. Stock muffler with headers. Stock stall stock trans stock gear stock height .
We just dynoed 688hp on the 50 shot on 93 octane pump gas.
1st time out was today at the track 11.58@118mph with a 1.83 60ft NO Nitrous! But on the nitrous tune with 3* of timing pulled .
How far do you plan to push yours ?
Has anybody made over 800 with a new 5.3 ? Only seen a handful make high hp so far
Old Dec 11, 2016 | 09:04 PM
  #79
07Softail's Avatar
So you have the LT4 pump and injectors also?
RT
Old Dec 11, 2016 | 09:56 PM
  #80
RT
Nope sir
