ordered cal tracs....rearend noise in reverse?
Old Jun 28, 2014 | 03:26 PM
LSall1991's Avatar
Default ordered cal tracs....rearend noise in reverse?
so i just ordered a set of caltracs for my truck. the kit for the flip kit trucks, saw another member already had these and liked the look but i also do some drag racing so it should help for dig racing. but also i can now zero out my thrust angle since i can never get it right after my 7" drop. its always like -.10 or posotive .10 degrees. anyways, before my drop kit i noticed that when i am in reverse backing up with the wheel cranked all the way either way i can hear and feel a clunk/bind type noise. im wondering if its my g80 or my leafsprings. or just normal. anyone with a 2014 notice this? i noticed when it was brand new in january but never paid any mind. now i beat the thing and slammed it and do burnouts lol. just wondering if anyone else has this issue
Old Jun 28, 2014 | 03:55 PM
musclecity85's Avatar
subscribed
i dont have a 14, but i have an 08 and i noticed the same thing, after lowering my truck. but i found no answers on what it is..
Old Jun 28, 2014 | 05:14 PM
cammed06's Avatar
I only went 6 in back, but didn't notice anything like that with or without cal tracs.
Old Jun 28, 2014 | 11:34 PM
LSall1991's Avatar
cal tracs are not on yet. they are on the way but i just figured id throw that in there.
Old Jun 29, 2014 | 09:32 AM
Bit's Avatar
Bit
I believe there is a problem in the steering rack. There is a bulletin on it. Mine is not dropped and does it. Started out only in reverse, but now it's all the time. I ordered the parts and will get it in the stall Monday or Tuesday to fix.
Old Jul 5, 2014 | 11:24 PM
LSall1991's Avatar
bit, thanks for the info. can you post the bulletin if you have it available? i notices when i go lock to lock with my steering right before it stops its a clunk even when parked. maby your onto something
Old Jul 6, 2014 | 12:27 AM
Bit's Avatar
Bit
The bulletin says to jack up the front and turn the wheels lock to lock, if you hear the popping noise, the problem is in the steering rack. I ordered the parts to fix it last week and they are on my work bench. I can't for the life of me remember what GM calls them. They are 2 rubber rings that go inside the rack, once you pull the tie-rod boots off.
Old Jul 9, 2014 | 10:58 PM
Bit's Avatar
Bit
Just to clarify, I installed the revised steering gear dampers and fixed the problem.
SloSVO
Nov 22, 2020 07:34 PM
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
turbo6c3
Oct 5, 2015 06:11 PM
Slammed silverado
Sep 28, 2015 06:14 PM
