need help 2014 silverado wheres the tps wire??
Old Feb 6, 2014 | 04:17 PM
JimmyLT's Avatar
Default need help 2014 silverado wheres the tps wire??
Ive looked all over the net trying to find this wire to hook up to my tps wot switch with no luck. Even the guys at NX couldnt help me with this problem. If anyone has any input it would be MUCH appreciated. Thanks
Old Feb 6, 2014 | 05:12 PM
Robert91RS's Avatar
I'm not familiar with NO2 or wiring up WOT switches so this is NOT my area of expertise but it appears to be the blue/white wire coming off the TB. Hope that helps somehow.
Q38 Throttle Body
Pin: 1
Color: YE
Circuit: 581
Function: Throttle Actuator Control Open
Terminal Type ID: I
Option: -
Pin: 2
Color: BN/WH
Circuit: 582
Function: Throttle Actuator Control Close
Terminal Type ID: I
Option: -
Pin: 3
Color: D-BU/WH
Circuit: 3630
Function: Throttle Position Sensor (SENT1) Signal
Terminal Type ID: I
Option: -
Pin: 4
Color: BK/BN
Circuit: 2752
Function: Throttle Position Sensor Low Reference
Terminal Type ID: I
Option: -
Pin: 5
Color: BN/RD
Circuit: 2701
Function: Throttle Position Sensor 5 Volt Reference
Terminal Type ID: I
Option: -
Connector Part Information
•Harness Type: Engine
•OEM Connector: 13699991
•Service Connector: 13581267
•Description: 6-Way F 0.64 GET Series, Sealed (BK)
Old Feb 7, 2014 | 05:54 AM
JimmyLT's Avatar
Thanks for the info i did try that wire and my WOT switch is getting a reading from it. It just wont calibrate so i think im going to go old school with a microswitch so i dont butcher up my harness anymore
Old Feb 7, 2014 | 08:36 PM
sammygroundzero's Avatar
Id go microswitch also safer for me till nx guys figure it out.
Is there a fuel port to tap into or has to be made?
Old Feb 9, 2014 | 07:54 PM
JimmyLT's Avatar
They are actually sending me the micro switch. And yes the kit comes with the fuel tap.
Old Feb 9, 2014 | 08:27 PM
62nalide's Avatar
Please post up with the outcome if you don't mind. Planning on running boost with NO2 on a 14'
Old Feb 12, 2014 | 07:29 AM
JimmyLT's Avatar
Video posted to the facebook site. Still not running 100 percent
Old Feb 12, 2014 | 09:13 AM
walledition's Avatar
post pictures man
Old Mar 8, 2014 | 07:10 AM
JimmyLT's Avatar
Im trying how do you get pictures on here
Old Mar 8, 2014 | 07:47 AM
Choda's Avatar
Link to Facebook? Let's see it
