My new work truck
Oh btw a guy on Camaro 6 has a built 10L surviving 1317 rwhp on a hub dyno. Ran 8.2 @ 173 @ 3750 race weight. Just in turned it up to 1544 same dyno. Expects 7's @ 180. It's a 427 with 2650R at 23 lbs. So looks like the 10L's have a future.
Sounds like your about to have some fun!
Waiting on hp tuners to return the ECM probably Monday. Supposed to pickup Wednesday or Thursday. Then try to get a few dragy's and then load it up with my tools and parts for AC season. Fun work truck hopefully. **** ton of $$ (Lingenfelter). Very excited still. Should kill my RCSB 5.3 Whipple truck, we'll see. It better!
You gonna keep both the 16 and 14?
Undecided got a lot going on. Keeping the 16 I'm pretty sure it's just so gorgeous. But that redhead...
ZO6Ted (04-10-2023)
Starting on low boost 6lbs I'm told. It's a work truck running hard in up to 102-112 deg. heat. Probably turn it up to at least 8lbs on 93 after the Summer. Should I do a chiller or just add meth for cooling and octane? Not for tuning but for cooling. I don't care about the $$ just the reliability for work. My season only lasts 5-7 months for 10 mos. income out of 12.
Got the fat girl back. They said # 1 and #3 had some bleed on cylinders so I'll follow up on that Can't do it now too busy. Gotta put it to work. and make that $$$ until Nov. Did a Dragy on the way home and it appears its maybe even with my '14 mph but had another 200lbs in it with old exhaust, intake and such, fuller tank of gas and much higher DA. Also 6 lbs advertised on 2650 vs 7.5 on the 2.9 14. Need a boost gauge next to see where I'm at. Dual 3" probably dropped it a bit. No 95 mm tb unfortunately . So mph is ok 60 ft sucks. More to do...2014 2.9 rcsb vs 6.2 2650 CC 2020 work truck. Not unhappy but want to turn it up a bit. Boost District in Midlothian did a beautiful job and cleaned it up under the hood with new wire looms and so on.
You need to change your sig now...
Nice! Glad you got it back. You will get it dialed in.
08DenaliAWDonVOGUES
06-23-2008 07:58 PM
